UCCX Upgrade - Historical Report Plugin
Dec 23rd, 2009
I am upgrading via transition to new hardware from IPCC 4.0(5) to UCCX 7.0(1)SR05.  I have a VM that runs Windows XP to generate the historical reports on a Daily, Weekly, and Monthly basis (another server then logs in, picks up the reports, and emails them).  The question is can I just upgrade the reporting client on that XP machine, and keep all my previously generated settings and schedule, or will I have to recreate all of that?  We have 20-ish CSQ's, and at 3 reports per CSQ being generated at 3 different schedules it will be quite a bit to recreate this.
So, has anybody done this successfully?
--Joe
Jonathan Schulenberg Wed, 12/23/2009 - 12:53
  • Cisco Designated VIP,
    2017 IP Telephony
It does not retain this by default; however, you should be able to save the report settings within the HRC (File > Save) and then open a saved report configuration once you upgrade to the new client version. You may want to practice this prior to upgrading to ensure you have valid saved files.
Related Content
