Cannot get my 3560G switch to talk to ESX 3.5 servers and the EMC NAS.
Answered Question
Dec 23rd, 2009
I have been trying for the past couple of weeks to get my 3560G switch to talk to a couple of ESX 3.5 servers, it's VC, and the EMC NAS. The goal is to implement 2 Etherchannels on the physical switch and NIC teaming on the vSwitch. One port-channel will have 1 VLAN traversing it, and the other port-channel will have 2 VLANs traversing it. VLANs were set up on the vSwitch to mirror the VLANs I have on the 3560G. I want to (have to) use load-balancing. Also, I have read other forums and websites to get some ideas on how to set this up, and each solution is different from the other. The problem seems to reside mostly in the VLAN configuration on the physical switch IMHO, because if I just make the switch a dummy switch, everything can talk without issue. The following information, I already know, not because it is my requirement, but rather pieces that must be present for the whole configuration to succeed.
All interfaces in an Etherchannel must belong to the same VLAN or be configured as trunks. I take this to mean that for the second port-channel, I have to configure the interfaces as trunks, since I need 2 different VLANs to traverse the link.  -I have tried configuring them as both trunks and access ports, and neither seemed to work.
vSwitch must be configured for "Route based on IP hash."
port-channel load-balance should use the src-dst-ip option.
flowcontrol receive desired should be set
system mtu jumbo 9000 should be set
Here is a snippet of my configuration:
port-channel load-balance src-dst-ip
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1     ------Port-channel2 is configured similarly to this one.
switchport trunk encap dot1q
switchport trunk native vlan 2
switchport trunk allowed 3     -----Po2 allows vlans 4,5 instead
switchport mode trunk
interface Gigabitethernet0/1     ------gi0/1 - 20 are configured similarly to this one.
switchport trunk allowed 3     -------gi0/13 - 14 allow vlan 4 and gi0/15 - 20 allow vlan 5
channel-group 1 mode on
Interface Gigabitethernet0/21 - 28 are shutdown
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address x.x.1.2 255.255.255.0
interface Vlan3 - 5 are configured identically
no ip address
ip default-gateway x.x.1.1
This should be enough to give you an idea on where I am and where I need to be. Any information you can provide would be greatly appreciated!
Correct Answer by Reza Sharifi about 7 years 4 months ago
Does you config work without using etherchannel?
On the ESX, I think the native vlan is 0, have you define that?
Also, you are using the 3560 as a layer-2 layer-3 device right?
Reza
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Wed, 12/23/2009 - 15:10
  • Cisco Designated VIP,
    2017 LAN
Reza
klambert1218 Wed, 12/23/2009 - 18:25
Hi Reza,
To be perfectly honest, I haven't tried it without Etherchannel because Etherchannel is a must for the system on which it is going to be used. As far as the ESX is concerned, a colleague of mine is responsible for that part of this task, although I'm sure he has it set up the correct way, I will make sure I inquire about that. Currently, the 3560G is functioning as a L2 device. I don't think I need to configure any ports as L3 because inter-VLAN communication is not necessary at this particular moment in time.
klambert1218 Mon, 12/28/2009 - 08:18
The native vlan on the ESX is set to vlan 2 also. Still nothing works.
klambert1218 Wed, 01/20/2010 - 10:16
I have since made changes on the ESX, like Route based on IP hash. I have also made more changes on the Cisco configuration. Some progress has been made, but not everything is as I need it to be.
klambert1218 Wed, 01/20/2010 - 10:21
This question is NOT answered. Still looking for assistance in this matter.
Reza Sharifi Wed, 01/20/2010 - 12:37
    2017 LAN
Hello Klambert,
Can you post your latest switch config?
Also, can you post diagram showing switch connectivity to VM server?
Reza
klambert1218 Thu, 01/21/2010 - 07:09
This is a snippet of pertinent information for my switch configuration. Also, I have attached a Visio diagram of how the switch connects to the ESX servers and the SAN (please excuse the crudeness).
no file verify auto
interface Port-channel1     ------Port-channels 2 and3 are configured similarly to this one.
switchport trunk allowed 3     -----Po2 allows vlan 4 and Po2 allows 5 instead
switchport nonegotiate
interface Gigabitethernet0/1     ------gi0/1 - 22 are configured similarly to this one.
switchport trunk allowed 3     -------gi0/13 - 16 allow vlan 4 and gi0/17 - 22 allow vlan 5
Interface Gigabitethernet0/23 - 28 are shutdown
interface Vlan1
no ip address
shutdown
interface Vlan2
no ip address
aeryilmaz Thu, 05/12/2011 - 13:55
Hi Klambert,
Curious if you ever got your issue resolved. I have a similar setup as you - ESX 3.5 servers, NICs are trunked and port-channeled. These ESX Hosts are currently passing traffic on various VLANs, but... I have added a new VLAN and attempting to connect these ESX hosts to a Storage appliance on that new VLAN. I ran a layer 2 trace and confirmed the path looks good from the ESX access switch and my Storage access switch, but they cannot talk to each other.
I can post more details, but curious what your resolution was?
Thanks in advance!
Related Content
