Can't get inbound or outbound calls coming in but POTS line is working?
Dec 23rd, 2009
So ive been working on my CUCM lab and trying to make calls work outbound to the PSTN but they are not working:
voice-port 1/1/0
connection plar opx 100
station-id number 100
voice-port 1/1/1
dial-peer voice 102 pots
destination-pattern 9[^1].........
port 1/1/0
dial-peer voice 103 pots
destination-pattern 911
port 1/1/0
forward-digits all
dial-peer voice 104 pots
destination-pattern 9678.......
port 1/1/0
dial-peer voice 100 pots
destination-pattern 9770.......
port 1/1/0
dial-peer voice 105 pots
destination-pattern 9404.......
port 1/1/0
dial-peer voice 106 pots
destination-pattern 91..........
port 1/1/0
dial-peer voice 107 pots
destination-pattern 9T
port 1/1/0
dial-peer voice 1 voip
destination-pattern 1..
voice-class h323 1
session target ipv4:10.0.1.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
I ran the show active voice calls command and got this when I was trying to make calls:
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 1
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Media call-legs: 0
Total call-legs: 2
GENERIC:
SetupTime=897479720 ms
Index=1
PeerAddress=100
PeerSubAddress=
PeerId=1
PeerIfIndex=16
LogicalIfIndex=0
ConnectTime=897482640 ms
CallDuration=00:00:21 sec
CallState=4
CallOrigin=2
ChargedUnits=0
InfoType=speech
TransmitPackets=1098
TransmitBytes=175680
ReceivePackets=1097
ReceiveBytes=175520
VOIP:
ConnectionId[0x800B4DBF 0x3C2531B3 0x21002101 0xA01010C]
IncomingConnectionId[0x800B4DBF 0x3C2531B3 0x21002101 0xA01010C]
CallID=72
RemoteIPAddress=10.0.1.1
RemoteUDPPort=17292
RemoteSignallingIPAddress=10.0.1.1
RemoteSignallingPort=52490
RemoteMediaIPAddress=10.1.1.12
RemoteMediaPort=17292
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=h245-alphanumeric
FastConnect=FALSE
Separate H245 Connection=TRUE
H245 Tunneling=FALSE
SessionProtocol=cisco
ProtocolCallId=
SessionTarget=
OnTimeRvPlayout=18100
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=65 ms
LoWaterPlayoutDelay=55 ms
TxPakNumber=909
TxSignalPak=0
TxComfortNoisePak=0
TxDuration=18190
TxVoiceDuration=18190
RxPakNumber=908
RxSignalPak=0
RxComfortNoisePak=0
RxDuration=18150
RxVoiceDuration=18100
RxOutOfSeq=0
RxLatePak=0
RxEarlyPak=0
RxBadProtocol=0
PlayDelayCurrent=55
PlayDelayMin=55
PlayDelayMax=65
PlayDelayClockOffset=-124553562
PlayDelayJitter=0 ms
PlayErrPredictive=0
PlayErrInterpolative=0
PlayErrSilence=0
PlayErrBufferOverFlow=10
PlayErrRetroactive=0
PlayErrTalkspurt=0
OutSignalLevel=-41
InSignalLevel=-42
LevelTxPowerMean=0
LevelRxPowerMean=0
LevelBgNoise=0
ERLLevel=9
ACOMLevel=9
ErrRxDrop=0
ErrTxDrop=0
ErrTxControl=0
ErrRxControl=0
ReceiveDelay=55 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
SRTP = off
TextRelay = off
VAD = disabled
CoderTypeRate=g711ulaw
CodecBytes=160
Media Setting=flow-through
CallerName=
CallerIDBlocked=False
OriginalCallingNumber=100
OriginalCallingOctet=0x0
OriginalCalledNumber=97705707990
OriginalCalledOctet=0xA8
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0xFF
TranslatedCallingNumber=100
TranslatedCallingOctet=0x0
TranslatedCalledNumber=97705707990
TranslatedCalledOctet=0xA8
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0xFF
GwReceivedCalledNumber=97705707990
GwReceivedCalledOctet3=0xA8
GwReceivedCallingNumber=100
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x81
MediaInactiveDetected=no
MediaInactiveTimestamp=
MediaControlReceived=
LongDurationCallDetected=no
LongDurCallTimestamp=
LongDurcallDuration=
Username=
Then on my dial peers:
sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
102    pots  up   up             9[^1].........     0                      up   1/1/0
103    pots  up   up             911                0                      up   1/1/0
104    pots  up   up             9678.......        0                      up   1/1/0
100    pots  up   up             9770.......        0                      up   1/1/0
105    pots  up   up             9404.......        0                      up   1/1/0
106    pots  up   up             91..........       0                      up   1/1/0
107    pots  up   up             9T                 0                      up   1/1/0
1      voip  up   up             1..                0  syst ipv4:10.0.1.1
UITS-2621XM#
I don't understand why I can't make outbound calls and receive them from the outside. Can someone please help me understand why? Would translation rules be a cause of this? I don't know how to configure them if they are, and i don't understand them much.
khayes1984 Thu, 12/24/2009 - 05:53
I see that my gateway is getting the incoming calls now but my phones aren't ringing or when I dial out the are ringing out, BUT I get this distorted noise. Any ideas?
pratik.rb Thu, 12/24/2009 - 06:05
Have you added the connection plar opx 110 to all voice-ports. If you dont add them the gateway wont accept incoming calls and caller will just hear ringing.
Secondly, in most of your POTS dial-peers you have not configured forward digit . By default the router will strip all digits explicitly matched on a dial-peer and only send the rest of digits.
For example dial-peer having destination-pattern 97800..... and you call 9780012345 will have 97800 removed and rest of number 12345 will be sent to PSTN. This may result in no-response or reorder.
khayes1984 Thu, 12/24/2009 - 06:25
plar opx 110:  you mean the other ext on my network?
pratik.rb Thu, 12/24/2009 - 06:31
Any incoming call on FXO - analog line does not contain DNIS (dialled number) unlike DID on PRI lines. So in order to route incoming calls to a IP Phone preferably to operator, put the following command under all voice-ports (FXO ports)
connection plar opx
khayes1984 Thu, 12/24/2009 - 07:39
I'm confused on which dial-peer i'm suppose to assign this too.
pratik.rb Sat, 12/26/2009 - 09:06
You apply "connection plar opx " to voice-port configuration not dial-peer. Every FXO port has a voice-port created in IOS configuration. This configuration will enable incoming calls to be directed towards a desired extension as configured in
khayes1984 Sat, 12/26/2009 - 09:54
I got outbound working, I'm working on Inbound. So I thought I had the correct configuration for incoming calls to work from the PSTN.... AGH!!
khayes1984 Sun, 12/27/2009 - 16:18
Finally got inbound and outbound working. I tried setting up my Caller-ID but my FXO card does not support it. Also Call Waiting, and having problems adding in calls when i have a active call on the line. I tried searching the administration guide, but I don't know what I'm looking for when it comes to setting up the Call Waiting, Three Waiting (Conferencing) etc.. I don't know where I need to look.
