Real Time Monitoring Tool ( CallManager )
Dec 23rd, 2009
Using the Real Time Monitoring Tool, can you provide instructions on how to pull down CDR records of Calls between two parties? ( this is in an effort to troubleshoot a calls that are unable to place outbound calls). It could be because of a Call Search Space issue, a PRI-line became unregistered, or maybe a gateway is down. So, I need to view the either the CDR records or trace log files.
Jaime Valencia Wed, 12/23/2009 - 20:13
  • Cisco Employee,
  • Hall of Fame,
    2011
CDR file won't give you any details from the ones you mention. You can simply look the call with CAR for that matter, you need to reach CUCM traces to troubleshoot.
Set Up Cisco CallManager Traces for Cisco Technical Support
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
