RTP question
Dec 23rd, 2009
May I know the answer with the following question.
1. In Cisco Product, such as voice gateway AS5400, router , should be accept any port range with RTP by default, or only accept a prot range from 16384-   32767  However, according to the book of Cisco VOIP , it's shows the "RTP is generally configured to use UDP ports in range 16384-32767.
   Which one is correct?
2. Could be the voice gateway such as AS5400, router which to fix the RTP port number for traverse to remote gateway for transport.
scpage Thu, 02/11/2010 - 16:15
  • Cisco Employee,
IOS will choose a local even numbered UDP port within the range of 16384 - 32767 for RTP.
This range is not configurable.
The remote device can choose any valid udp port.
