SRST 7206 router
Dec 24th, 2009
I want to know that is there cisco 7206 (7200 series) router support SRST feture or not ?...
rob.huffman Thu, 12/24/2009 - 07:33
Hi J,
The 7200 series is still "not" supported
SRST Supported Platforms
Cisco Platform
Cisco 880 SRST ****
Cisco 1861
Cisco 2801
Cisco 2811
Cisco 2821
Cisco 2851
Cisco 3825
Cisco 3845
Catalyst 6500 CMM**
*** Cisco Caalyst 6500 CMM supports Cisco Unified SRST 4.0 with Cisco IOS Release 12.4 and supports Cisco Unified SRST 2.1 with Cisco IOS Release 12.2(13)ZC.
**** SRST 880 is natively supported by CUCM 6.13 and 7.1
Hope this helps!
cgrimard26 Fri, 09/24/2010 - 06:25
The 7206VXR does support SRST.  I am currently at version IOS 12.4(18c) and I have Call-Manager-fallback functionality. I am trying to figure out what is the highest IOS that I can go to before the SRST functionality is stripped out.  Cisco has striped out the SRST functionality because they want people to purchased their ISR Branch routers, like a 3825. So I am still trying to find out what the highest IOS version is that still contains SRST functionality.
Thanks for anyones support.
Steven Holl Fri, 09/24/2010 - 07:18
The last mention of the 7200 in SRST platform support is here:
In theory, if it is available on 12.4(18c), then you can run the latest mainline and still get those features.
That being said,I just tested it, and I can get it up on 12.4(22)T.  It at least takes the commands.  I'm going to circle back with our BU because we either need to correct the platform documentation, or remove 'call-manager-fallback' in certain releases:
F340.11.14-7200-12#sh ver
Cisco IOS Software, 7200 Software (C7200-ADVIPSERVICESK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Technical Support:
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 10-Oct-08 10:10 by prod_rel_team
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
F340.11.14-7200-12 uptime is 3 weeks, 1 day, 23 hours, 47 minutes
System returned to ROM by reload at 00:17:13 UTC Sat Jan 1 2000
System image file is "disk0:c7200-advipservicesk9-mz.124-22.T.bin"
Last reload reason: Reload Command
F340.11.14-7200-12#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
*Jan 23 23:47:46.339: %LINEPROTO-5-UPDOWN: Line protocol on Interface EDSP0, changed state to upmax-dn ?
  <1-1000>  Maximum single/dual/octo line  directory numbers supported
F340.11.14-7200-12(config-cm-fallback)#max-dn 1000
