Bricked NSS4000
Dec 24th, 2009
After unsuccessfull firmware upgrade my NSS4000 does not boot. It simply shows yellow power led, then blinking green power led.
I tested the "red blinking" recovery procedure by usb but it doesn't work.
What I can try before RMA it?
Alejandro Gallego Sat, 12/26/2009 - 20:20
  • Cisco Employee,
Try removing ALL drives once the NSS is shutdown and then reboot (with drives ejected). If you end up in the same place; blinking Green Power light, perform a factory reset and try again. Factory reset will not erase disk data, just settings. If you are still not successful call Small Business Support Center.
giolam Sun, 12/27/2009 - 01:03
I did it. Same behaviour. So last resource is RMA.
Ela Snessjna Mon, 01/04/2010 - 23:59
I have the exact same problem! Any solution for it? At the moment the thing is down :(
