Multiple Fax line requirement
I have a prospect with 7 incoming fax lines over AT&T SIP trunks.  They need to be processed differently based on incoming DID.  My plan is to get them to a server with a smar modem.  The fax volume is not great, it's just that the client needs a lot of lines for business reasons.
Questions:
1.  Can I send several incoming fax  DIDs to a single FXS port on a UC?
2.  Can I encode the DID into DTMF tones which a fax card in a server will convert back to DIDs for processing decisions?
3.  Any other solution recommendations?
matt.slaga Wed, 12/30/2009 - 18:39
If the trunks are already SIP, I would recommend a boardless fax solution like XMedius.  This would handle the routing and processing of incoming faxes without the need to convert to/from analog.
http://sagem-interstar.com/
Marcos Hernandez Sun, 01/03/2010 - 09:20
  • Blue, 1500 points or more
The answer to the first question is yes. Others have weighed in regarding the other two.
Marcos
Related Content
