WAAS Software download error
Dec 24th, 2009
Ihave download the WAAS upgarde 4.1.5b to a unit and have seen the following message in the log
"Software Upgrade/Downgrade: the version [4.1.5.b.1 given in the meta file does not match the version of the image file [4.1.5.b.7]"
Is this a concern, do I need to rerun the download, how can I cancel the upgrade ?
Eric Rose Fri, 12/25/2009 - 16:56
  • Cisco Employee,
When you type "show version" what is listed in the output? You should be all set...
The complete image should be listed as WAAS-4.1.5b.7
Eric
dan_ungureanu2004 Mon, 06/11/2012 - 23:16
Hello guys,
I know that this is a very old topic but unfortunately i stumbled on the same issue and i didn't find any solution yet.
It's the same warning that Ian got :
The user input errors in the software upgrade meta file
Software Upgrade/Downgrade: the version [4.4.1.0.1 given in the meta file does not match the version of the image file [4.4.1.0.12]
Software relase is 4.4.1 (build b12 May 27 2011)
Version: oe-vwaas-4.4.4.12
Regards.
