N7K
Dec 24th, 2009
Got 3 Qs:
1) how do you save the config on N7K, or on NX in general?
2) How to do image upgrade?
3) Do I need to congif STP? and if so, do I need to config a switch as root? & how I can do that?
Thx.
mohAmed khAdr Fri, 12/25/2009 - 13:01
What am asking is: do you just:  wr mem like IOS to save the config,.... or it's like the CatOS..just enter2wice.
Thx.
Jerry Ye Wed, 12/30/2009 - 15:33
  • Cisco Employee,
wri mem is not a valid CLI in the NXOS, you have to use copy run start.
For software upgrade procedure, please check out the upgrade guide.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/upgrade/guide/Cisco_Nexus_7000_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide__Release_4.2_chapter1.html
By default, STP is disabled in NXOS. If you have the proper license, you can enable STP, and configure it to fit your environment.
jerry
mohAmed khAdr Wed, 02/10/2010 - 14:28
Jerry,
Can you pls. avise on config redundancy for sup 1 on n7k?
Thx.
Jerry Ye Wed, 02/10/2010 - 15:29
  • Cisco Employee,
Can you post the output of the following commands after inserting the module standby SUP
show system redundancy status
show module
show boot auto-copy
jerry
Trending Topics: Storage Networking
