INTERVLAN Ping Issue
Answered Question
Dec 25th, 2009
Hello Guys,
                I have 2 VLANS setup on a layer 3 switch. I have dhcp scopes handing out ip addresses for both VLANS by the same layer 3 switch. I can ping anything in VLAN 3 from VLAN 2 as long as it recieved a ip address from DHCP with no problem. My problem is I have 2 servers plugged into the
same switch using VLAN 3 static ip addresses. I can not ping them at all from VLAN 2 but I can ping them from any device inside of VLAN 3. Why is this and how do I correct it?
Correct Answer by glen.grant about 7 years 4 months ago
I agree sounds like the default gateways  were not defined on the static servers  or  you are trying to ping a device that has a software firewall  running and blocking your ping request.
Correct Answer by Nagendra Kumar ... about 7 years 4 months ago
Check if you have default gateway configured on the servers?.
Nagendra
Overall Rating: 5 (2 ratings)
Ganesh Hariharan Fri, 12/25/2009 - 20:41
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Please post your configuration ,it is not clear what exactly is happening .
Ganesh.H
Correct Answer
Nagendra Kumar ... Fri, 12/25/2009 - 21:19
  • Cisco Employee,
Nagendra
Charlie Mayes Sat, 12/26/2009 - 06:34
Thanks I can't believe I missed that. My other server had the default gateway set. I must have been more tired than I thought.
Correct Answer
glen.grant Sat, 12/26/2009 - 05:32
Charlie Mayes Sat, 12/26/2009 - 06:35
