Cannot access PAP2T after upgrade to 5.1.6
Dec 25th, 2009
I have a PAP2T, unlocked, brand new.
I set my system password, looked over the options, ext
After I was comfortable with it I searched for new firmware. I had 3.1.5.
I found 5.1.6, downloaded it and installed it.
It appeared to go well, no problems that I could see.
When I accessed it all looked well, firmware was 5.1.6.
When I went to Advanced, system, It asked for password, and would not accept my last password.
It was entered by Norton utilities, so I am sure I did not enter it incorrectly.
After reading up on this i found the **** 73738# 1 trick, tried it, but still asked for password.
I entered my userid and password, and admin enter. Neither worked.
Is there a way to get back into this?
I have the software recovery tool, I expect this is for firmware 5.1.5, so I am hesitant using it.
Alberto Montilla Mon, 01/04/2010 - 03:50
Dear Sir;
User id cannot be changed so it is always admin or user. Pleas try this with your password, that should work.
