DHCP server
Answered Question
Dec 26th, 2009
I config 3 VLANs in the network. There is one DHCP server per VLAN. I would like to achieve following:
VLAN 1: 192.168.11.0
DHCP svr: 192.168.11.23
backup DHCP svr: 192.168.12.23 and 192.168.13.23
VLAN 2: 192.168.12.0
backup DHCP svr: 192.168.11.23 and 192.168.13.23
VLAN 3: 192.168.13.0
DHCP svr: 192.168.13.23
backup DHCP svr: 192.168.11.23 and 192.168.12.23
Device: Catalyst 3750
Any missing in the config as below?
rdgs
--- config ---
interface GigabitEthernet1/0/1
description VLAN 1
switchport access vlan 1
switchport mode access
interface GigabitEthernet1/0/2
description VLAN 2
switchport access vlan 2
interface GigabitEthernet1/0/3
description VLAN 3
switchport access vlan 3
interface Vlan1
description User segment 1
ip address 192.168.11.1 255.255.255.0
ip helper-address 192.168.12.23
ip helper-address 192.168.13.23
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan2
description User segment 2
ip address 192.168.12.1 255.255.255.0
ip helper-address 192.168.11.23
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan3
description User segment 3
ip address 192.168.13.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
----- end ----
Correct Answer by Ganesh Hariharan about 7 years 2 months ago
Configuring DHCP you need to create pools for alloting ip address for particular vlan,check out the below link for configuraing dhcp in cisco switches.
http://www.cisco.com/en/US/docs/routers/access/1800/1801/software/configuration/guide/dhcpvlan.pdf
and check out the sample configuration regarding dhcp.
ip dhcp pool pool1
   network 10.10.1.0 255.255.255.0
   default-router 10.10.1.1
   dns-server what.ever.ip.itis
ip dhcp pool pool2
   network 10.10.2.0 255.255.255.0
   default-router 10.10.2.1
   dns-server what.ever.ip.itis2
vlan 10
ip address 10.10.1.1 255.255.255.0
vlan 20
ip address 10.10.2.1 255.255.255.0
the default-router command ties that pool to the interface (vlan)
Hope that helps out your query !!
Ganesh.H
Correct Answer by Jon Marshall about 7 years 2 months ago
rdgs
--- config ---
description VLAN 1
description VLAN 2
description VLAN 3
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan2
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan3
no ip redirects
no ip unreachables
no ip proxy-arp
----- end ----
Anita
There is nothing missing but be aware that all DHCP servers will be used for each vlan so the local DHCP will see the request but also the 2 ip helper-addresses will see the request per vlan as well. The local one should be the first to respond but that is not always a given.
So you need to make sure that each DHCP server hands out unique addresses per vlan ie. 3 DHCP servers per vlan means each DHCP server is responsible for a 3rd of the subnet for that vlan. You cannot have 2 or more DHCP servers responsible for the same address.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Sat, 12/26/2009 - 06:59
rdgs
--- config ---
description VLAN 1
description VLAN 2
description VLAN 3
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan2
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan3
no ip redirects
no ip unreachables
no ip proxy-arp
----- end ----
Anita
Jon
Correct Answer
Ganesh Hariharan Sat, 12/26/2009 - 07:01
ip dhcp pool pool1
ip dhcp pool pool2
vlan 10
vlan 20
Ganesh.H
