QoS on ASA
2044418Puts
Hi, I would like do use Priority Queuing for voice on the OUTSIDE interface. As far as I know the QOS meganism only kicks in when there is congestion on the interface. But my ASA 5505 is connected to a 80mbps down and 10 mbps up cable modem. How can I tell the ASA that it is not connected to an interface with 100/100 mbps bandwidth?
On a router I would use the bandwidth command, but this is not available on the ASA as far as I know.
Thanks!
Kureli Sankar
You are correct.
Traffic shaping is used to match device and link speeds, thereby controlling packet loss, variable delay, and link saturation, which can cause jitter and delay.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/qos.html#wp1065649
Example: Shaping outside interface traffic to 2 Mbps and provide priority queueing for VoIP traffic that is tagged with DSCP EF and AF13:
    class-map voice_traffic
        match dscp EF AF13
    policy-map qos_class_policy
        class voice_traffic
           priority
    policy-map qos_outside_policy
       class class-default
          shape average 2000000 16000
          service-policy qos_class_policy
    service-policy qos_outside_policy interface outside
-KS
Kureli Sankar
You are correct.
        match dscp EF AF13
        class voice_traffic
           priority
       class class-default
-KS
Sorry for my late response, but thanks a lot, I'm looking into it and see if it works.
I've just tried to configure like you said, but for some reason no traffic is matching classes other than class-default.
priority-queue OUTSIDE
service-policy OUTSIDE_PM interface OUTSIDE
policy-map OUTSIDE_PM
class class-default
  shape average 4504000
  service-policy SHAPED_OUTSIDE_PM
policy-map SHAPED_OUTSIDE_PM
class VOICE_CM
  priority
class LLQ_ACL_CM
  priority
class IKE_ACL_CM
  priority
class class-default
class-map VOICE_CM
match dscp cs3  af31  ef
class-map IKE_ACL_CM
match access-list IKE_ACL
class-map LLQ_ACL_CM
match access-list LLQ_ACL
access-list IKE_ACL line 1 extended permit udp any eq isakmp any
access-list IKE_ACL line 2 extended permit udp any any eq isakmp
access-list LLQ_ACL line 1 extended permit udp any eq 9987 any
I'm trying to achieve the following:
  • Shape the whole output to 4.500.000 bits / sec
  • Prioritize outgoing voicetraffic + voicecontrol to a priority queue within the shaper
    • DSCP values have been verified using wireshare and the ASA capture feature.
    • The match statement should match regular outgoing voice, but also the outgoing voice via VPN connections. I think the last thing happens by default since according to the manual the ASA uses QOS Pre-classification by default.
  • Prioritize outgoing traffic according to the LLQ_ACL
    • Inside my DMZ network i'm also running a Teamspeak server on UDP port 9987. This port has been PAT'ed through the asa from the OUTSIDE to the DMZ.
    • Since the packets are being send from DMZ UDP port 9987 to clients with a random high port number, I've set the ACL accordingly.
  • Prioritize outgoing VPN Control / IKE traffic.
    • This one speaks for itself. There are two VPN connections running.
I let this configuration running for a while, then I did a "show service-policy int OUTSIDE" and it turned out that only the class class-default had any matches:
Interface OUTSIDE:
  Service-policy: OUTSIDE_PM
    Class-map: class-default
      shape (average) cir 4504000, bc 18016
      (pkts output/bytes output) 85882/21745072
      (total drops/no-buffer drops) 99/0
      Service-policy: SHAPED_OUTSIDE_PM
        Class-map: VOICE_CM
          priority
          Queueing
          queue limit 75 packets
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 0/0
        Class-map: LLQ_ACL_CM
          priority
          Queueing
        Class-map: IKE_ACL_CM
          priority
          Queueing
          Default Queueing
          (queue depth/total drops/no-buffer drops) 0/99/0
          (pkts output/bytes output) 85884/21745154
Can anyone tell my why this is happening and why the other classes are not being matched?
Thanks!
Panos Kampanakis
You can also look at that has a similar example as KS's.
https://supportforums.cisco.com/docs/DOC-1230#Traffic_Policing_with_Prioritization
I hope it helps.
PK
