CiscoWork Network Management
indika.gamage
Herewith I have attacehd the CiscoWork specification. Please help to correct software to meet the requitrement/
Reg,
Indika
7 Replies 7
Joe Clarke
Nothing is attached, but it's not clear from your post exactly what information you want.  Do you want specific hardware recommendations (e.g. vendor and model) for running LMS?
Hi Joe
Actually I need suitable software model for the attached technical specification. Please find the attached spec.
Reg,
Indika
You still have not attached anything.
Hi Joe
Technical Specifications for Network Management and Monitoring System
Minimum Specification
2.4.4 General Requirements
2.4.4.1 Network discovery, topology views, end-station tracking, and VLAN management
2.4.4.2 Real-time network fault analysis with easy-to-deploy, device-specific, best-practice templates
2.4.4.3 Hardware and software inventory management, centralized configuration tools, and syslog monitoring
2.4.4.4 Monitoring and tracking of network response time and availability
2.4.4.5 Real-time device and link management, as well as port traffic management, analysis, and reporting
2.4.4.6 A flexible Web portal for launching and navigating network management functionality
2.4.4.7 A workflow engine that provides step-by-step wizards for system setup and device troubleshooting
2.4.4.8 Support for system-defined MIB templates enables easy polling setup
2.4.4.9 Historical reporting on a daily, weekly, monthly, and annual basis
2.4.4.10 Comprehensive reporting such as Device Dashboard, Custom Reports, Top-N/Bottom-N Reports
2.4.4.11 Threshold breach event notification, reporting, and event handler support
2.4.4.12 Role-based access control
2.4.4.13 An easy to use GUI
2.4.4.14 Firewall, VPN, IPS Configuration and Management
2.4.4.15 Policy-based Management
2.4.5 Warranty
2.4.5.1 3 years comprehensive
Reg,
Indika
You should really talk to your SE or account manager to make sure you get everything you need.  This is especially true when it comes to the support side.  However, it sounds like a combination of CiscoWorks LAN Management Solution and Cisco Security Management Suite will give you the required functionality.  You will also need the extra CiscoWorks Health and Utilization Monitor addon for LMS to get the performance and trending features.
See http://www.cisco.com/go/lms for more details on LMS and http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns171/ns625/ns647/net_brochure0900aecd80400060_ps6498_Products_Brochure.html for more on CSM.    More on HUM can be found at http://www.cisco.com/hum .
Hi Joe
Thanks for your reply. Yes, Firewall, VPN, IPS Configuration and Management are not come with CiscoWorks LAN Management Solution. Pls help to get correct solution for this.
Reg,
Indika
That's why I said you also need Cisco Security Management Suite.  This will provide the firewall and IPS management.
