FWSM on 6513 switch
Answered Question
Dec 27th, 2009
Dear All,
We have FWSM on 6513 core switche, we configure it in routed mode without natting (by just typing "no nat-control" command). Now i face a problem which is, the users in the inside interface can't access the Internet although i can ping any Internet site through the outside interface.
Also, Not all the vlans on the core switch are passing through FWSM so, how can i permit the users that passthrough FWSM to communicate with the other vlans that are on the core switch.
please find below the configuration of the FWSM:
interface Vlan254
nameif outside
security-level 100
ip address 172.29.254.200 255.255.255.0
interface Vlan800
nameif Inside1
security-level 100
ip address 10.50.10.2 255.255.255.0
interface Vlan820
nameif Inside2
security-level 100
ip address 10.50.20.2 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list test extended permit ip 10.50.20.0 255.255.255.0 10.50.10.0 255.255.255.0
access-list test extended permit ip 10.50.10.0 255.255.255.0 10.50.20.0 255.255.255.0
access-list test extended permit ip 10.50.10.0 255.255.255.0 172.30.240.0 255.255.255.0 >>>>> (172.30.240.0 is the subnet that dosen't passthrough FWSM and created on the core switch)
access-list test extended permit ip any any
access-group test in interface Inside1
access-group test in interface Inside2
route outside 0.0.0.0 0.0.0.0 172.29.254.1 1
Correct Answer by Jon Marshall about 7 years 6 months ago
Where are the 10.x.x.x addresses getting Natted as these are not routable on the Internet. Also does the MSFC on the 6500 know how to get to the 10.x.x.x addressing ie. you can either
1) exchange routing information between the MSFC and the FWSM
OR
2) you can have static routes on the MSFC ie.
ip route 10.50.10.0 255.255.255.0 172.29.254.200
ip route 10.50.20.0 255.255.255.0 172.29.254.200
if you use option 2) then any other vlans connected to the 6500 will be able to route to the 10.50.x.x addressing. If you have remote sites or other vlans not routed on the 6500 then you will need to redistribute the above statics into your routing protocol.
Well you need to allow the traffic but it looks like you have done that. I would check the routing as above.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Sun, 12/27/2009 - 09:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
OR
Jon
hebaelshahat Mon, 12/28/2009 - 06:23
Jon,
thanks a lot for your reply.
i already use option 2 but unfortunately the ip route command was wrongly configured.
Jon Marshall Mon, 12/28/2009 - 09:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
hebaelshahat wrote:
Jon,
No problem. Presumably this fixed both issues ?
Jon
hebaelshahat Mon, 12/28/2009 - 10:10
Hi Jon,
yes the two issues are fixed, but users on vlan 800 can't ping users on vlan 820 and vice vers although i open ping on all the interfaces.
Also, i'd like to configure failover between two FWSM on two 6513 core switches and i'll configure active/standby single mode failover but i cann't find any configuration example. can you help me in that issue?
thanks in advance!
Heba
Jon Marshall Mon, 12/28/2009 - 10:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
hebaelshahat wrote:
Hi Jon,
thanks in advance!
Heba
Heba
Here is the config chapter for failover for the FWSM -
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/configuration/guide/fail_f.html
As for communication between vlan 800 and vlan 820, can you pass any traffic between these 2 vlans ?
Jon
hebaelshahat Mon, 12/28/2009 - 10:26
yes i can pass traffic between them but they can't ping each other.
Jon Marshall Mon, 12/28/2009 - 10:35
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Okay, not sure what is happening as permit ip should include ICMP and if you can pass traffic then it shows your config is okay. Have you got ICMP inspection enabled on the FWSM ?
Jon
