how to Telnet from firewall to router ???
Dec 27th, 2009
Dear All,
i am trying to telnet from my firewall to router through command promt....it gives me a black blank with a - .....what are the parameters to be configured to access the router.
Ganesh Hariharan Mon, 12/28/2009 - 00:35
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Configure teh follwoing in your router end and then check the telent connectivity from firewall.
Router(config-line)#line vty 0 ?
<1-4> Last Line Number
Router(config-line)#line vty 0 4
Router(config-line)# password admin2
Router(config-line)# login
Hope this helps out your query !!
Ganesh.H
Jon Marshall Mon, 12/28/2009 - 01:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
sibgathullah wrote:
Dear All,
Mohammed
You cannot telnet from the firewall to anything, it is not allowed as it is a security feature.
The "telnet ..." command on the pix/ASA is used to allow certain IP addresses to telnet to the firewall.
Jon
Ganesh Hariharan Mon, 12/28/2009 - 02:09
Thanks jon for the clarification i was think some other way round for telnet option into router via firewall.
Ganesh.H
Jon Marshall Mon, 12/28/2009 - 02:14
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Ganesh.H
Ganesh
No problem. Think that's one of the reasons we all do NetPro because we all continually learn new things.
Jon
sibgathullah Wed, 12/30/2009 - 06:03
Dear Jon,
Thanks for your reply, i was aware of that but i was trying to find a way out for telnet.
