12-28-2009 01:21 AM - edited 07-03-2021 06:22 PM
Hi All,
In WLC, Can I get the serial number of SFP in WLC by GUI or CLI? Seems that the GUI cannot provide this information but this information is useful for inventory management.
Thanks.
Best Regards,
Teru Lei
12-28-2009 02:33 PM
No.. I dont believe you can... There is no mechnism for the SFP to transmit its information. Good question ...
12-03-2014 09:27 AM
I know that this Topic is very old, but I was facing the same issue.
The solution is:
Connect via CLI (SSH) to WLC and type "debug fastpath cfgtool --dump.sfp"
you dont need to type "FP0.", thats part of the output
I censored the output with XXXXXX:
(Cisco Controller) >debug fastpath cfgtool --dump.sfp
(Cisco Controller) >FP0.
Port SFP Vendor Transceiver Type OUI PartNumber Rev SerialNumber DateCode Auth
1 OEM (0x01)1000BaseSX GLC-SX-MM-G-UL 2.0 VB11XXXXXX 110701 ok
2 Not Present (0x00)NOT_SUPPORTED fail
3 Not Present (0x00)NOT_SUPPORTED fail
4 Not Present (0x00)NOT_SUPPORTED fail
5 Not Present (0x00)NOT_SUPPORTED fail
6 Not Present (0x00)NOT_SUPPORTED fail
7 Not Present (0x00)NOT_SUPPORTED fail
8 Not Present (0x00)NOT_SUPPORTED fail
FP0.
hope that helps someone for the next time
12-14-2015 12:18 AM
12-14-2015 02:06 PM
Probably a little late but via GUI [Controller] [Inventory]
44020 version 7.0.240.0
12-28-2009 03:30 PM
Try "show inventory".
12-28-2009 06:36 PM
I thought you might be on to something ... but just checked my 4402 and no love ...
I dont think you can get the serial from an SFP on a WLC
12-28-2009 09:49 PM
Awwww nuts!
02-09-2010 11:12 PM
sh inventory.
Right you are !!!
Thank you !!!
02-09-2010 11:48 PM
If it works, can you please rate my post? Thanks.
02-10-2010 10:14 AM
Yes, sure.
Five stars !!
Thank's for your help ! It's very useful !
02-10-2010 11:57 AM
Peter,
What WLC and Code version are you on!? I checked gain on 2 different WLC running 6x and 4x and both arent showing the SFP info...
(Cisco Controller) >show inventory
Burned-in MAC Address............................ XXXXXXXXXXXX
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
NAME: "Chassis" , DESCR: "4400 Series WLAN Controller:25 APs"
PID: AIR-WLC4402-25-K9, VID: V01, SN: XXXXXXXXXXX <--- This serial number is of the controller
08-30-2011 04:14 AM
Hi there!
Any update on this topic?
11-11-2015 02:32 PM
