How is it possible to increase capacity of transcoder sessions?
Answered Question
Dec 28th, 2009
Correct Answer by babatunde_sanda about 7 years 1 month ago
"webstd.design" is right by saying increasing your dsp resources but if you are simply referring to altering the sessions, you can do that from your router configuration under the dspfarms.  The word "Capacity" is pretty broad.
first check the dsp resources " show voice dsp".  If you have more, then simply go under your transcoder dspfarm and alter the maximum sessions.
dspfarm profile 10 transcode
  maximum sessions 5
no shu
Correct Answer by Paolo Bevilacqua about 7 years 1 month ago
By installation of additional DSP modules.
Overall Rating: 3.5 (2 ratings)
Correct Answer
babatunde_sanda Tue, 12/29/2009 - 12:49
  maximum sessions 5
no shu
webstd.design Thu, 12/31/2009 - 05:25
Additional one question
If I have several routers, is it possible to use them as one entity without installation additional DSP on only one router?
gogasca Thu, 12/31/2009 - 11:56
It depends which codecs are enabled, depending the codec complexity number of sessions increase or decreased, this is associated to the MIPS in DSPs
Take a look at CUCM SRND Media Resources section
