How I can notify supervisor if there aren't any agents logged in?
Dec 28th, 2009
Is it possible to do with Cisco Supervisor Desktop?
Thank you in advance
Overall Rating: 5 (2 ratings)
Marwan ALshawi Mon, 12/28/2009 - 03:48
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
this one way
when a call comes if there is no agent in loggedin state an email will be sent to the supervisor
the can be done by adding get reporting statistics before the cal go to the queue and then make if step
check if the number of logged in agents = 0 then send eamil if no normal
if you want go to advenced level you may use trigger application and then you run another script that call the supervisor number and play a prompt one no agent loggedin !
good luck
if helpful Rate
Jonathan Schulenberg Mon, 12/28/2009 - 06:08
  • Cisco Designated VIP,
    2017 IP Telephony
Just keep in mind that this solution is only possible if you have a Premium license as you need the SMTP subsystem to be activated.
