RVL200 - How to connect to ssl vpn with a Macbook Pro??
Dec 28th, 2009
How do I connect to the RVL200 SSL vpn or IPsec vpn from a Macbook Pro running Snow Leopard? I have tried using the Safari browser and Google Chrome and neither seem to connect.
jckconsultant Sun, 01/31/2010 - 20:52
What you won't find in the user manual you refer to, or in the specifications listed on the Linksys / Cisco website, is what version(s) of Mac OS X are supported.  I found this out the hard way, after purchasing the router to find it only works with version OS X 10.4. Linksys business customer support was not helpful at all, and seemed unaware of this fact.
I later found this information from the v1.1.7 firmware release notes:
11. Virtual Passage supports Mac OS X 10.4.x (with Safari), Linux (with Firefox 2) and Windows 2000/XP/Vista (with Internet Explorer 6/7, Netscape Communicator 8, and Firefox 2.)
Meaning OS X 10.5 doesn't work, which is the version I had at the time.  10.5 was released in October 2007, and support for it has never been added.  I wouldn't hold my breath waiting for 10.6 support.
