OSPF routes on VRF
Answered Question
Dec 28th, 2009
Hello:
Is it possible that External and Inter-Area routes don't be propagated on VRF if it is on an area different to zero?. In a 6500 with FWSM I could see that kind of routes are installed on routing table on both (MSFC and FWSM) but it doesn't happen on VRF, external and IA routes are not installed.
Between MSFC and FWSM there is a SVI in area 1 and all is ok; between FWSM and VRF there is another SVI in area 1. I tried to place all of them in area 0 and now the VRF installs all routes correctly, why?.
Correct Answer by Giuseppe Larosa about 7 years 2 months ago
Hello Fdelcura,
some tuning may be needed
capability vrf-lite
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_osp1.html#wp1012376
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Francisco Del Cura Mon, 12/28/2009 - 08:04
It was the problem!!!, I introduced the command and now the VRF install External and IA routes
Thanks Giuseppe!!
