Cisco 6500 PPPoE
Answered Question
Dec 28th, 2009
Need to setup 6500 as pppoe server, I am not seeing commands I have on other platforms such as ( bba-group , vpdn-group )
Whats needs to be done to use a 6500 as a pppoe server?
Correct Answer by Giuseppe Larosa about 7 years 4 months ago
Hello Dan,
it looks like your C6500 has a supervisor 2 installed from the image name that appears in show ver.
if so MPLS requires specialized linecards like OSM or WAN gigabit interfaces.
AToM (Any Transport over MPLS) could be of help allowing you to send the PPP sessions to some other device but it is not possible at the moment if you haven't at least a sup 720 3BXL.
I would have been surprised to see PPPoE supported on this platform. If you have a C7200 VXR it can be a valid solution.
Hope to help
Giuseppe
Overall Rating: 5 (3 ratings)
Daniel Graham Mon, 12/28/2009 - 07:32
Running 12.2(18)SXF16
vpdn command is not there. Should I be running a different version?
ansalaza Mon, 12/28/2009 - 08:05
  • Cisco Employee,
12.2SX
This command is supported in the Cisco IOS Release 12.2SX train. Support in a specific 12.2SX release of this train depends on your feature set, platform, and platform hardware.
Could you provide us the output of show version?
Daniel Graham Mon, 12/28/2009 - 08:26
IOS (tm) s222_rp Software (s222_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF16, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Tue 03-Mar-09 14:13 by kellythw
Image text-base: 0x40101040, data-base: 0x42C7EAA0
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: s222_rp Software (s222_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF16, RELEASE SOFTWARE (fc2)
WT01 uptime is 5 days, 21 hours, 26 minutes
Time since WT01 switched to active is 5 days, 21 hours, 25 minutes
System returned to ROM by  power cycle (SP by power-on)
System image file is "disk0:s222-adventerprisek9_wan-mz.122-18.SXF16.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
[email protected] WS-C6506 (R7000) processor (revision 3.0) with 458752K/65536K bytes of memory.
Processor board ID SAL0847642W
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
1 FlexWAN controller (1 ATM)(1 Channelized T3).
2 Virtual Ethernet/IEEE 802.3 interfaces
10 Gigabit Ethernet/IEEE 802.3 interfaces
4 Serial network interfaces
1 ATM network interface
1 Channelized T3 port
381K bytes of non-volatile configuration memory.
If
cisco
32768K bytes of Flash internal SIMM (Sector size 512K).
ansalaza Mon, 12/28/2009 - 08:57
  • Cisco Employee,
Only these vpdn/ppoe commands are available for 12.2SX
clear vpdn tunnel pppoe (12.2SX)
debug vpdn pppoe-data (12.2SX)
debug vpdn pppoe-error (12.2SX)
debug vpdn pppoe-events (12.2SX)
debug vpdn pppoe-packet (12.2SX)
vpdn aaa attribute (12.2SX)
debug pppoe (12.2SX)
debug pppoe redundancy (12.2SX)
Reza Sharifi Mon, 12/28/2009 - 08:50
  • Cisco Designated VIP,
    2017 LAN
Dan,
Using the feature navigator, this feature is not supported on the 6500 series.
I am running 12.2.(33)SXI and I tried it and the command is not there.
Reza
Daniel Graham Mon, 12/28/2009 - 09:24
Is there a way I can handoff pppoe sessions to an external server? L2TP?
I need to terminate 100 ATM PVCs on this router, or an external pppoe server.
Daniel Graham Mon, 12/28/2009 - 09:27
I am new to MPLS, could this be benifical to me in this situation?
I also do not have to use pppoe, although I would prefer to.
Correct Answer
Giuseppe Larosa Mon, 12/28/2009 - 12:02
  • Hall of Fame,
    Founding Member
Hello Dan,
Hope to help
Giuseppe
