Upgrade from 5.1(3) to 7.1
Dec 28th, 2009
Hello.
We are currently on CM 5.1(3) and looking to go to 7.1. We use two HP DL380-G5 servers. We don't have any UCSS contracts for UCM. There is no server replacement - 7.1 replace 5.1 on the same server.
It is my understanding that I need to buy:
1 media kit x CM7.1-K9-380G5 (SW Only, Unified CM 7.1 For HP DL380-G5) and
2 node license to activate the new features - LIC-CM7.1-7835 (License Unified CM 7.1 7835 Appliance)
Is this correct? Or am I mistaken?
Thanks!
Rob Huffman Mon, 12/28/2009 - 08:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi AS,
Yes, you are on the right track here
As far as Licensing goes,this upgrade also requires the Software Feature License.
Here is a clip that speaks to this issue;
When you upgrade from an earlier release of Cisco Unified Communications Manager to Release 7.0(2), you must download and install a software feature license to activate the new features. This applies to CUCM 7.1 as well
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_0_2/cucm-rel_notes-702.html#wp616664
***You should receive a PAK with the 7.x Upgrade Media***
Use this procedure to obtain a software feature license:
Procedure
Step 1 Navigate to the License Registration web tool at http://www.cisco.com/go/license.
Step 2 Enter the Product Authorization Key (PAK) that you received with your Cisco Unified Communications Manager upgrade.
Step 3 Click Submit.
Step 4 Follow the system prompts. You must enter the MAC address of the Ethernet 0 NIC of the first node of the Cisco Unified Communications Manager cluster. You must also enter a valid e-mail address.
The system sends the license file to you via e-mail by using the e-mail address that you provided. To view the contents of a software feature license, refer to "License File Contents" in the Cisco Unified Communications Manager System Guide.
Step 5 You must upload the software license file to the server with the matching MAC address that you provided in Step 4.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b02licfu.html#wp1067359
Here is a clip from a CCM Ordering Guide
"A license must be ordered for each server in a Unified Communications Manager cluster irrespective of server function (e.g. MOH, TFTP, warm standby server, etc). **This would be the "node" license. So you need two node licenses
It would look something like this;
1x CM7.1-K9-DL380
2x LIC-CM7.1-7835= these are the "Node" licenses
Hope this helps!
Rob
