EIGRP metric calculation?
Answered Question
Dec 28th, 2009
I have a 6513 with EIGRP routing protocol.
When I try to calculate the EIGRP metric of a interface loopback 0, using the
bandwidth value and delay value that show interface loopback 0 command.
es-plcdatacenter2#sh int loo
es-plcdatacenter2#sh int loopback 0
Loopback0 is up, line protocol is up
  Hardware is Loopback
  Internet address is 172.16.3.36/32
  MTU 1514 bytes, BW 8000000 Kbit, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Last input 00:00:02, output never, output hang never
  Last clearing of "show interface" counters 1w3d
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     189839 packets output, 11390340 bytes, 0 underruns
es-plcdatacenter2#
es-plcdatacenter2#
but when I was used the "SHOW IP EIGRP TOP x.x.x.x/x" command, I  see the next information "Minimum bandwidth is 10000000 Kbit"
What about that?
In this link http://ccie-en-espanol.blogspot.com/2009/05/eigrp-mtu-y-metrica.html#comment-form
I found the following information:
Some default values for Bandwidth and Delay associate to some interfaces type are listen on the next table
Media.........Bandwidth..Delay
FastEthernet...100000K...100µS
Ethernet........10000K...1000µS
T1..............1544K....20000µS
DS0..............64K....20000µS
56K..............56K....20000µS
es-plcdatacenter2#
es-plcdatacenter2#sh ip eigrp top 172.16.3.36/32
IP-EIGRP (AS 4944): Topology entry for 172.16.3.36/32
  State is Passive, Query origin flag is 1, 1 Successor(s), FD is 128256
  Routing Descriptor Blocks:
  0.0.0.0 (Loopback0), from Connected, Send flag is 0x0
      Composite metric is (128256/0), Route is Internal
      Vector metric:
        Total delay is 5000 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 1514
        Hop count is 0
I will apreciate some assistance about that.
David Salazar
Correct Answer by Jon Marshall about 7 years 6 months ago
nando02 wrote:
Giuseppe
Thank a lot,  for your valuable information.
Can you give me a technical reference where it is define the use of truncated method for EIGRP metric calculation?
I was thinking about the use of this method before writing on the Cisco Support Community but I do not find technical reference. I tried to remeber that I was read about it long time ago but I don't have writing reference.
Every time that  division result in numerical fractional is used truncated method?
David
From the EIGRP whitepaper section on metric calculation -
Cisco routers do not perform floating point math, so at each stage in       the calculation, you need to round down to the nearest integer to properly       calculate the metrics
Full link -
EIGRP metrics
Jon
Correct Answer by Giuseppe Larosa about 7 years 6 months ago
Hello David,
I would say it is a resolution problem.
With effective settings the contribute of BW to metric is : (10^7 / 8000000)*256 = 1.25 *256
the metric is calculated taken the truncated version of 1.25 = 1
you see metric as 128256 = 500*256 + 256*1
using 1,25 it would be: 500*256+1,25*256 = 128320
then the sh ip eigrp topology expands the metric in the two components giving 5000 microseconds and 10000000 kbps
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Mon, 12/28/2009 - 13:14
  • Hall of Fame,
    Founding Member
Hello David,
Hope to help
Giuseppe
David Salazar Mon, 12/28/2009 - 13:59
Giuseppe
Correct Answer
Jon Marshall Mon, 12/28/2009 - 14:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
nando02 wrote:
Giuseppe
David
Full link -
EIGRP metrics
Jon
