LMS 3.2 Java support
Answered Question
Dec 28th, 2009
Will LMS 3.2 support Java 1.6.0_17 and
higher?
Correct Answer by Joe Clarke about 7 years 3 months ago
Yes, it does with one caveat.  Currently, cross-launches from the Campus Manager Topology Map will not work with JVM higher than 1.6.0_11.  This is a bug we are pursuing with Sun.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 12/28/2009 - 12:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
sirbaughmf Wed, 12/30/2009 - 05:00
One more question regarding this issue, I read the help test and it's
a bit confusing, perhaps you can clarify:
Prerequisites to Launch Topology Services
To access Campus Manager Topology Services, we recommend that you install Java Plug-in version 1.6.0_11. If the client machine is installed with the JRE Update version equal to or higher than the recommended version, then Topology Services is launched in the client machine.
If the client machine is installed with an Update version equal to or higher than the recommended JRE version (1.6.0_11), then Topology Services will be launched only if either one of two versions is selected.
If the user selects the recommended JRE as well as the higher Update version of JRE, Topology Services will be launched with the higher Update version of JRE.
For example, CM 5.2 requires JRE 1.6.0_11 to launch Topology Services. If the client machine is installed with an Update version higher than JRE 1.6.0_11, say 1.6.0_12, and user selects JRE 1.6.0_12, then Topology Services is launched with JRE 1.6.0_12.
My understanding is that if I have a version higher than update 11, topology services will open with that version.  I have update 17 loaded and selected in the control panel, however, when I try to open TS I get the Installation of Java.....window opening.  Do I need update 11 in addition to any other java loaded?  or should it load with update 17 only?
Joe Clarke Wed, 12/30/2009 - 09:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
LMS 3.2 should launch with any JPI greater than or equal to 1.6.0_11.  This came about due to bug CSCsy29287.  Exactly what window are you seeing?  Post a screenshot.
Joe Clarke Wed, 12/30/2009 - 10:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You may need to reinstall JPI 1.6.0_17.  The code in LMS checks the browser's configured MIME types to see that Java Web Start is properly installed.  It's looking for the MIME type application/x-java-applet;version=1.6 or application/x-java-applet;version=1.6.0.  You should also check IE > Tools > Internet Options > Advanced to make sure you have checked the box to enable JPI 1.6.0_17 for tags.
sirbaughmf Wed, 12/30/2009 - 11:02
I believe the JPI is installed correctly, there have been restrictions placed on the configuration in this environment. See below of specific configurations that have been put into place...do you see any that would affect the launching of java?
#deployment.properties
#Wed Dec 09 14:32:00 DST 2009
deployment.browser.path=C\:
Program Files
Internet Explorer
iexplore.exe
deployment.browser.vm.iexplorer = true
deployment.browser.vm.iexplorer.locked
deployment.browser.vm.mozilla = false
deployment.cache.jarcompression.locked
deployment.cache.jarcompression=3
deployment.cache.jarcompression=5
deployment.cache.max.size.locked
deployment.cache.max.size=500
deployment.capture.mime.types=true
deployment.console.startup.mode=hide
deployment.control.panel.log = True
deployment.control.panel.log=True
deployment.javapi.cache.update = false
deployment.javapi.cache.update=true
deployment.javapi.lifecycle.exception = false
deployment.javaws.associations.locked
deployment.javaws.associations=never
deployment.javaws.autodownload.locked
deployment.javaws.autodownload=NEVER
deployment.javaws.cache.update=true
deployment.javaws.home.jnlp.url =
deployment.javaws.installURL.locked
"deployment.javaws.installURL="""""
deployment.javaws.jre.0.args=
deployment.javaws.jre.0.enabled=true
"deployment.javaws.jre.0.location="""""
deployment.javaws.jre.0.osarch=x86
deployment.javaws.jre.0.osname=Windows
deployment.javaws.jre.0.path=C\:
Program Files
Java
jre6
bin
javaw.exe
deployment.javaws.jre.0.platform=1.6
deployment.javaws.jre.0.product=1.6.0_17
deployment.javaws.jre.0.registered=true
deployment.javaws.muffin.max = 256
deployment.javaws.shortcut.locked
deployment.javaws.shortcut=NEVER
deployment.javaws.ssv.enabled = False
deployment.javaws.ssv.enabled=False
deployment.javaws.uninstall.shortcut = false
deployment.jpi.mode.new=false
deployment.proxy.bypass.list.locked
deployment.proxy.override.hosts.locked
deployment.proxy.type.locked
deployment.proxy.type=3
deployment.repository.askdownloaddialog.show = false
deployment.repository.askdownloaddialog.show = False
deployment.repository.askdownloaddialog.show=False
deployment.repository.enabled = false
deployment.repository.enabled=false
deployment.security.askgrantdialog.notinca.locked
deployment.security.askgrantdialog.notinca=false
deployment.security.askgrantdialog.show.locked
deployment.security.askgrantdialog.show=false
deployment.security.authenticator = true
deployment.security.browser.keystore.use = true
deployment.security.browser.keystore.use.locked
deployment.security.clientauth.keystore.auto = true
deployment.security.clientauth.keystore.auto.locked
deployment.security.expired.warning.locked
deployment.security.expired.warning=True
deployment.security.https.warning.show = true
deployment.security.https.warning.show.locked
deployment.security.https.warning.show=true
deployment.security.jsse.hostmismatch.warning = true
deployment.security.jsse.hostmismatch.warning.locked
deployment.security.notinca.warning = true
deployment.security.notinca.warning.locked
deployment.security.password.cache.locked
deployment.security.password.cache=false
deployment.security.pretrust.list = true
deployment.security.pretrust.list.locked
deployment.security.pretrust.list=true
deployment.security.sandbox.awtwarningwindow = true
deployment.security.sandbox.awtwarningwindow.locked
deployment.security.sandbox.jnlp.enhanced = False
deployment.security.sandbox.jnlp.enhanced.locked
deployment.security.sandbox.jnlp.enhanced=False
deployment.security.SSLv2Hello = false
deployment.security.SSLv2Hello.locked
deployment.security.SSLv3 = true
deployment.security.SSLv3.locked
deployment.security.TLSv1 = true
deployment.security.TLSv1.locked
deployment.security.trusted.policy =
deployment.security.validation.crl = True
deployment.security.validation.crl.locked
deployment.security.validation.crl=True
deployment.security.validation.ocsp = True
deployment.security.validation.ocsp.locked
deployment.security.validation.ocsp=True
deployment.system.tray.icon.locked
deployment.system.tray.icon=false
deployment.update.mime.types = true
deployment.version=6.0
Marcie Sirbaugh
Joe Clarke Wed, 12/30/2009 - 11:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't think that these settings would prevent the JavaScript code from detecting the JPI.  Do you have the box checked under IE > Tools > Internet Options > Advanced to use JPI 1.6.0_17 for tags?  You could also try installing Firefox 3.0, and see if it can launch topology.
sirbaughmf Mon, 01/04/2010 - 05:50
Yes, I have the applet tag selected in the browser and unfortunately Firefox has not been approved to work in our environment....anything else you can think of to check?
Marcie Sirbaugh
Joe Clarke Mon, 01/04/2010 - 08:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You could try setting your security level to low in IE for your LMS server's zone.  As I said, the Campus code must be able to read the installed MIME types in the browser (using JavaScript), and the "application/x-java-applet;version=1.6" must exist.
As for Firefox, simply testing to see if it works would let you know if you have a plug-in problem vs. a browser problem.  Note: you may need to reinstall JPI 1.6.0_17 before trying.
sirbaughmf Wed, 01/27/2010 - 12:09
Hi Joe,
This is still a very big issue for us, we are completly unable to work with Topology Services at this point.  We are narrowing the issue down, I believe it must have something to do with LMS not being able to read the installed MIME types in the browser (using JavaScript), and the "application/x-java-applet;version=1.6".  Is there a registry entry on the Windows PC where it reads this?  I have done a workaround that seems to work, but not going to proceed in production environment with it, but it might help in troubleshooting.  I changed the following file:
topoServices.jsp
    if (javawsInstalled)
            location.replace ("/JSP/CAMPUS/campus/campusws.jsp?app=Topology_Services&WSInstalled=true");
                        if(navigator.appName == "Microsoft Internet Explorer"){
                window.opener=self;
                setTimeout('window.opener.close()', 1000);
                }else{
                setTimeout('window.close()', 5000);
    else
This seems to tell LMS that java is there and then it proceeds to using it....otherwise it can't find it.  I'm wondering when update 17 was installed, if when it uninstalled the previous version of 1.6, it corrupted something and it wasn't completely removed, causing conflict somewhere.
Any thought?  thanks, Marcie
Joe Clarke Fri, 01/29/2010 - 17:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Try creating a virgin user account on this machine.  Then see if the problem persists.  If it does, try another machine with JPI 1.6.0_17 to rule out problems with the plug-in.  I have a feeling the problem will be localized to one account or one machine at the most.
