ACESM & FWSM design query
Answered Question
Dec 28th, 2009
Dear ,
we have 2x6509 each conatins sup720-VSS , ACE20 & FWSM module to implement as Data-Centre Aggregation switches.
Now regarding our Data-centre we have 2 subnets and all our servers are in these 2 subnets. And we dont want to pass all traffic which we dont want to loadbalance thru ACE.We just want to pass all traffic thru MSFC and then FWSM(we will put all security features here) and then we will forward traffic to ACE(allow any any access list) if SLB desired otherwise directly to server.
But the main issue here is that we are hosting servers with slb requirement and non-slb servers in same subnet. So i just want to know considering this limitation above scenario we want is possible or not?
Wali
Correct Answer by Gilles Dufour about 7 years 3 weeks ago
Wali,
no problem with the design.
This is actually a common solution.
Gilles.
Overall Rating: 5 (1 ratings)
Gilles Dufour Wed, 12/30/2009 - 01:13
Wali,
this is possible but more complicated,
   Internet
         MSFC
        FWSM---- ACE
  Subnet1  Subnet2
The flow client---> ACE ---> servers is not a problem with this design.
The concern is the response from the servers.
You need a way to force the FWSM to send the response to ACE and not directly to the client on the Internet.
And only for traffic that was loadbalanced.
You only have 2 options.
1/ Do client nat for all traffic going through ACE. Easy to do.  But you lose information about client source ip address on the servers.
For HTTP, you could keep this information by instructing ACE to insert this info in the http header.
2/ Put the MSFC right after FWSM as well and implement policy-routing on the MSFC . Based on src ip and tcp src port decide to send the traffic to ACE or not.
It is much better to create a subnet for LB servers and put this subnet behind the ACE module.
   Internet
         MSFC
        FWSM---- ACE ----- LB_Subnet
  Subnet1  Subnet2
Gilles.
KFU NOC Wed, 12/30/2009 - 01:53
Thanks Gilles !
Suppose if i choose to put FWSM above MSFC and do PBR on MSFC for SLB severs in subnet1 & subnet2.
Is there any flaw from design point in this solution.
   Internet
         FWSM
       MSFC---- ACE
  Subnet1  Subnet2
Wali
Correct Answer
Gilles Dufour Wed, 12/30/2009 - 08:13
Wali,
Gilles.
