QoS on 3750G
Dec 29th, 2009
Dear All,
I configured QoS on 3750G switch to give priority for the Video, IPTV and Voice traffic going to another site.
The physical WAN link is 1G, but the service provides is only providing 400Mbps.
//Match voice traffic and VOIP traffic coming from the LAN1
access-list 116 permit ip any any dscp 46
access-list 117 permit ip 192.168.1. 0.0.0.255 any
class-map LAN1_VOIP
match access-group 116
class-map IPTV
match access-group 117
class-map VIDEO
//set new DSCPs (EF for voice and dscp41 for IPTV, AF31 for all other traffic)
policy-map LAN1_INPUT
class LAN1_VOIP
  set dscp 46
class IPTV
  set dscp 41
class class-defaut
  set dscp af31
policy-map VIDEO_INPUT
class VIDEO
  set dscp 41
interface g1/0/14
description FROM_LAN1
service policy input LAN1_INPUT
interface g1/0/8
service policy input VIDEO_INPUT
-->So now voice and video traffic will be mapped to Q1, all other traffic will be mapped to Q3
interface GigabitEthernet1/0/28
description TO_WAN
srr-queue bandwidth share 1 80 10 10
srr-queue bandwidth shape  5  0  0  0
srr-queue bandwidth limit 40
priority-queue out
mls qos
So the Queuing mapping will be as follow:
Q1: is for Voice, Video and IPTV (the actual traffic is around 150Mbps
Q2: currently no traffic in this queue but will be used for LAN2
Q3: for other traffic coming from LAN1
Q4: currenty no traffic in this queue but will be used for LAN2
So Q2,Q3 and Q4 should share the remaining bandwidth .
after i applied the above configuration the voice and video traffic (around 150M) was very good by monitoring it in the another site, but the file transfer (Q3) was slow (it takes only around 130M of the remaining traffic  although I have available bandwidth), so do i need to add another configurations to solve the problem.
Thanks and regards
Giuseppe Larosa Tue, 12/29/2009 - 01:47
  • Hall of Fame,
    Founding Member
Hello Justanas1,
your configuration looks like correct and interesting specially this command:
Use the srr-queue bandwidth limit interface configuration command on the switch stack or on a standalone switch to limit the maximum output on a port. Use the no form of this command to return to the default setting.
Usage Guidelines
If you configure this command to 80 percent, the port is idle 20 percent of the time. The line rate drops to 80 percent of the connected speed. These values are not exact because the hardware adjusts the line rate in increments of six.
this may mean that 40 is seen as 36.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/command/reference/cli3.html#wp1947391
The priority queue is served first that is the objective of the priority queue.
So unfortunately on the other queues you get what is left by the priority queue.
A file transfer is an FTP transfer that is TCP based so packets are not simply sent they are sent within the TCP window of the sender that acts based on acks received from the receiver.
Probably this is the best you can get with this multilayer switch that has no outbound queueing and no hierachical QoS like a router.
Hope to help
Giuseppe
justanas1 Tue, 12/29/2009 - 02:31
Hi Giuseppe,
Thank you for your reply.
before i applied the QoS, the FTP was fast and arrived arround 300M, so i think it is not windowing problem.
Anas
Marwan ALshawi Tue, 12/29/2009 - 05:27
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
hi Anas
as Giuseppe mentioned above, when you enable the priority queue in the switch this queue will be serviced first and even more it will not be governed by the shape limit !!! that's why you need to take this into your considerations when you enable it
good lcuk
if helpful Rate
justanas1 Tue, 12/29/2009 - 10:33
hello,
I monitored the link before and after enabeling the QoS,
before i enabled the QoS, the Video, IPTV and Voice were utilizing arround 120M and i started FTP session, the one session tooke arround 200M.
But after i enabled the QoS, the Video, IPTV and Voice utilized arround 120M then i tested FTP session it utilized only 50M although the link has available BW and i checked that using solarwinds.
Anas
Marwan ALshawi Tue, 12/29/2009 - 20:27
just make sure from the dscp to cos maping as you have the set command used dscp and the queuing in the switch consider cos
set dscp >> local dscp- cos map>> cos queues
