I have a QOS issue
Dec 29th, 2009
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hello everybody
I need help in QOS issue, we have 2 branches A and B, A connected via MPLS "Frame-relay" with 2 Mbps connection and B the same like A but with 256Kbps connection, both of the 2 branches connected via the MPLS cloud with many other branches, but only A and B configured with QOS.
And here is the configuration
1-Router A
Class match-any voice
Match protocol rtp
Match access-group 101
Policy-map voice
Class voice
  Set dscp ef
  Priority 1024
Class-default
  Set dscp default
Policy-map voiceA
Class-default
  Shape average 2048000
  Service-policy voice
Int serial 0/3/0.1
Max-reserved bandwidth 90
Service-policy out voiceA
Access-list 101 permit ip 20.1.0.0 0.0.255.255  20.1.0.0 0.0.255.255
Note:all voice lans have this range
2-Router B
Match protocol rtp
Policy-map voice
Class voice
  Set dscp ef
  Priority 128
Class-default
  Set dscp default
Policy-map voiceB
Class-default
  Shape average 256000
Int serial 0/1.1
Service-policy out voiceB
the problem
when there is a traffic from A to B "DATA not VOICE" it saturate the INBOUND link of branch B, ok and no voice calls initiated yet.
BUT, when a call initiated voice from B to A is good "outbound of B"
And voice from A to B "inbound to B" so so bad, WHY??
The inbound to B only come from A ok, and data marked with dscp=0 and voice marked with dscp = ef, and the Service provider assure the QOS through its network
Note both A and B policy maps match the pakets and mark it, I checked it using sh policy-map int
Note during saturation of data I traced from A to B using voice subnet and delay = 50 ms in all hops except the last hop "from service provider to B" it equals 300 ms
Any one has any idea??
Thnx for your time
babatunde_sanda Tue, 12/29/2009 - 12:16
Your problem is with this command
Int serial 0/1.1
You are only using 10 percent of the interface bandwitch for you classified and marked traffic.
By default 25 percent of the interface is resevered.  That leaves 75% for your policy map.  But you went and reservered more.  So your policy map is using the remaining 10% since you reserved 90% for what you didn't explicitly classify and mark. (That command is there for you to shoot yourself in the foot which seems like you succeeded in doing). Cisco recommends not reserving more than 25% of the interface bandwidth.
If you are just trying to give your voice precedence over any other traffic (which you should), you could revert that configuration to the default and simply use you configurations.  It could be as simply as
Match protocol rtp-audio (if you don't specify both audio and video will be marked)
Policy-map voice
Class voice
  Set dscp ef
  Priority 1024
class class-default
fair-que
random-detect dscp-based
Int serial 0/3/0.1
Max-reserved bandwidth 25
Access-list 101 permit ip 20.1.0.0 0.0.255.255  20.1.0.0 0.0.255.255 dscp ef  (Use this or the second line)
access-list 101 permit ip any any dscp ef
access-list 101 permit udp any any range 16384 32767
access-list 101 permit ip any any precedence critical
cheers.
If this helps, pls rate.
