I have a QOS issue
Dec 29th, 2009
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hello everybody
I need help in QOS issue, we have 2 branches A and B, A connected via MPLS "Frame-relay" with 2 Mbps connection and B the same like A but with 256Kbps connection, both of the 2 branches connected via the MPLS cloud with many other branches, but only A and B configured with QOS.
And here is the configuration
1-Router A
Class match-any voice
Match protocol rtp
Match access-group 101
Policy-map voice
Class voice
  Set dscp ef
  Priority 1024
Class-default
  Set dscp default
Policy-map voiceA
Class-default
  Shape average 2048000
  Service-policy voice
Int serial 0/3/0.1
Max-reserved bandwidth 90
Service-policy out voiceA
Access-list 101 permit ip 20.1.0.0 0.0.255.255  20.1.0.0 0.0.255.255
Note:all voice lans have this range
2-Router B
Match protocol rtp
Policy-map voice
Class voice
  Set dscp ef
  Priority 128
Class-default
  Set dscp default
Policy-map voiceB
Class-default
  Shape average 256000
Int serial 0/1.1
Service-policy out voiceB
the problem
when there is a traffic from A to B "DATA not VOICE" it saturate the INBOUND link of branch B, ok and no voice calls initiated yet.
BUT, when a call initiated voice from B to A is good "outbound of B"
And voice from A to B "inbound to B" so so bad, WHY??
The inbound to B only come from A ok, and data marked with dscp=0 and voice marked with dscp = ef, and the Service provider assure the QOS through its network
Note both A and B policy maps match the pakets and mark it, I checked it using sh policy-map int
Note during saturation of data I traced from A to B using voice subnet and delay = 50 ms in all hops except the last hop "from service provider to B" it equals 300 ms
Any one has any idea??
Thnx for your time
Marwan ALshawi Tue, 12/29/2009 - 04:56
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
the problem here is your connection in site A is sending traffic in a higher rate than B
can handel in the case your link i A side will start dropping in the SP side
as long you are using MQC not frame-relay traffic shaping
in router A you need to shape the interface that sending traffito site B
if you have a specific DCLI going to Site B
than instead of using class-default for the shaper
create class map that match the DLCI going to Site B
class-map map1
match fr-dlci [dlci toward site b]
Policy-map voiceA
Class map1
service policy ---- this one need to be reconfigured to accommodate the new shaped bandwidth
if you do not have a DLCI for Site B only use ACL that match source and destination that represent traffic gong to Site B and use this class instead of class map1 in the example above
this way you will shape the traffic from Site A to B with 256K .
good luck
if helpful Rate
Ahmed Zein Tue, 12/29/2009 - 13:41
dear Marwan, thnx for your reply
but i did what u talked about , i did this shaping with an ACL "which match the data traffic only" where we didn't have specific dlci for branch B, but what is the result?? nothing only the sound sounds better when i shape in a low rate ,
Shape average 256000 >>>>bad sound in B
Shape average 128000>>>>good sound in B
Shape average 96000>>>>very good sound in B
any soln????
or i should shape the all traffic (voice and data)???
Marwan ALshawi Tue, 12/29/2009 - 16:03
you need to shape all of you traffic to 256k and within the 256 k you can prioritize
your voice traffic
with your shaper use bc of 2560 to make the tc to the lowest interval which is 10ms best practice with voip
shape avarrage 256000 bc 2560
good luck
if helpful Rate
