%SYSTEM-1-INITFAIL: Network boot is not supported.
GIULIO FAINI
I have a 6500 with 2 SUP7203B running SXI3 and after I reload slot 5, it tries to boot using a bootstring I never configured and that  is not in the bootvar...
string is bootdisk:s72033-ipservicesk9-mz.122-33.SXI3.bin
see below for the complete output log.
Now the 6500  is stuck looping forever with this error:
If i break and i try to type boot ot boot sup-bootflash:s72033-ipservicesk9-mz.122-33.SXI3.bin, it still try to use the bootdisk: string...
Both sup-bootflash have the image SXI3 in sup-bootflash:.
Here is the data i collected.....
EUMAIXRM01_RM03#sh boot
BOOT variable = sup-bootflash:s72033-ipservicesk9-mz.122-33.SXI3.bin,1;slavesup-bootflash:s72033-ipservicesk9-mz.122-33.SXI3.bin,1;
CONFIG_FILE variable =
BOOTLDR variable =
Standby is up
Standby has 524288K/65536K bytes of memory.
Standby BOOT variable = sup-bootflash:s72033-ipservicesk9-mz.122-33.SXI3.bin,1;slavesup-bootflash:s72033-ipservicesk9-mz.122-33.SXI3.bin,1;
Standby CONFIG_FILE variable =
Standby BOOTLDR variable =
Standby Configuration register is 0x2102
EUMAIXRM01_RM03#sh modul
Mod Ports Card Type                              Model              Serial No.
  3   16  SFM-capable 16 port 1000mb GBIC        WS-X6516-GBIC      SAL0751QWN0
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1109JK0H
  6    2  Supervisor Engine 720 (Hot)            WS-SUP720-3B       SAL1149900R
  7   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1218P8E6
Mod MAC addresses                       Hw    Fw           Sw           Status
  3  000e.83af.2fd8 to 000e.83af.2fe7   5.5   6.3(1)       12.2(33)SXI3 Ok
  5  0017.9444.7e28 to 0017.9444.7e2b   5.3   8.4(2)       12.2(33)SXI3 Ok
  6  0019.e8ba.e7c0 to 0019.e8ba.e7c3   5.6   8.5(2)       12.2(33)SXI3 Ok
  7  001f.ca6f.3870 to 001f.ca6f.389f   2.7   12.2(14r)S5  12.2(33)SXI3 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  5  Policy Feature Card 3       WS-F6K-PFC3B       SAL1110JPDF  2.3    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL1109J1GV  2.6    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3B       SAL11488U7C  2.3    Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL11488PE5  3.1    Ok
  7  Centralized Forwarding Card WS-F6700-CFC       SAL1218PC3N  4.0    Ok
Mod  Online Diag Status
  3  Pass
  5  Pass
  6  Pass
  7  Pass
When i reload this is the output log:
EUMAIXRM01_RM03#reload
Proceed with reload? [confirm]
Dec 29 09:37:31: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
Dec 29 09:37:31: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
Dec 29 09:37:31: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Dec 29 09:37:34: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*** --- SHUTDOWN NOW ---
Dec 29 09:37:34: %SYS-SP-5-RELOAD: Reload requested by Delayed Reload. Reload Reason: reload.
Dec 29 09:37:34: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
System Bootstrap, Version 8.4(2) Release
Copyright (c) 1994-2005 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootflash:s72033-ipservicesk9-mz.122-33.SXI3.bin"
Loading image, please wait ...
Invalid device specified
Booting from default device
Initializing ATA monitor library...
Self extracting the image... [OK]
Self decompressing the image : ################################################################################################################################################################################################## [OK]
monitor: command "boot" aborted due to user interrupt
rommon 1 > boot sup-bootflash:s72033-ipservicesk9-mz.122-33.SXI3.bin
I also tried to type i to initialize.....
14 Replies 14
burleyman
Level 8
Level 8
Can you post your boot commands that are configured and also the output of
DIR ALL
Mike
vvasisth
The bootvar is pointing to bootdisk. According to release notes, we must use sup-bootdisk:
to boot if he is using a ATA 512MB:
** Supervisor Engine 720 Common Features
• Integrated 720-Gbps Switch Fabric
• 64-MB bootflash device or CompactFlash adapter with 512 MB CompactFlash card
(WS-CF-UPG=):
– 64-MB bootflash device (sup-bootflash:) supported in all releases
– WS-CF-UPG= (sup-bootdisk:) supported in:
— Release 12.2(18)SXE5 and later releases
— Release 12.2(18)SXF and later releases
Please change the bootvar with: "bootsystem flash
sup-bootdisk:s72033-ipservices_wan-mz.122-18.SXF6.bin", save the configuration and try
again.
Make sure that the above statement is the first one in the bootvar list, if needed delete
the old boot statement.
Release notes are located here:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/ol_4164.htm#wp2560955
You need to chnage the name to sup-bootdisk and that should work.
Hope that helps.
regards,
Varun
Thanks Varun
I will change it to sup-bootdisk,
anyway do you have idea how to get out of rommon now... it is stuck rebooting forever...
i try to do
rommon 2 > boot sup-bootdisk:s72033-ipservicesk9-mz.122-33.SXI3.bin
but still insists in...
if its in rommon mode
just ebter "boot" and hit ebter
this will make the sup come up with the 1st valid IOS image it comes across in the memory.
Varun
This supervisor i reload is in slot 5.
I tried but it keeps rebooting and rebooting.
Only after I send a BREAK and type boot, it boots correctly and it goes in standby mode as the other supervisor in slot 6 is active.
PLease see below the full output.
EUMAIXRM01_RM03#sh bootvar
BOOTLDR variable =
Standby is up
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#sh module
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
.Jan  4 12:15:14: %BGP-5-ADJCHANGE: neighbor 160.213.118.33 Down NSF peer closed the session
.Jan  4 12:15:15: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3/15, changed state to down
.Jan  4 12:15:15: %LINK-3-UPDOWN: Interface GigabitEthernet3/15, changed state to down
EUMAIXRM01_RM03#
Jan  4 12:15:15: %LINEPROTO-SP-5-UPDOWN: Line protocol on Interface GigabitEthernet3/15, changed state to down
.Jan  4 12:15:15: %HSRP-5-STATECHANGE: Vlan914 Grp 4 state Active -> Init
.Jan  4 12:15:15: %HSRP-5-STATECHANGE: Vlan916 Grp 6 state Active -> Init
.Jan  4 12:15:15: %HSRP-5-STATECHANGE: Vlan917 Grp 7 state Active -> Init
.Jan  4 12:15:15: %HSRP-5-STATECHANGE: Vlan918 Grp 8 state Active -> Init
.Jan  4 12:15:15: %HSRP-5-STATECHANGE: Vlan919 Grp 9 state Active -> Init
EUMAIXRM01_RM03#P-5-STATECHANGE: Vlan933 Grp 111 state Active -> Init
.Jan  4 12:15:15: %HSRP-5-STATECHANGE: Vlan942 Grp 12 state Active -> Init
Jan  4 12:15:15: %LINK-SP-3-UPDOWN: Interface GigabitEthernet3/15, changed state to down
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
EUMAIXRM01_RM03#
--More--
.Jan  4 12:18:42: %LINK-3-UPDOWN: Interface GigabitEthernet3/15, changed state to up
--More--
Jan  4 12:18:42: %LINK-SP-3-UPDOWN: Interface GigabitEthernet3/15, changed state to up
--More--
.Jan  4 12:18:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3/15, changed state to up
--More--
Jan  4 12:18:45: %LINEPROTO-SP-5-UPDOWN: Line protocol on Interface GigabitEthernet3/15, changed state to up
--More--
.Jan  4 12:18:48: %BGP-5-ADJCHANGE: neighbor 160.213.118.33 Up
i RELOAD SLOT 5 ACTIVE SUP720
Jan  4 12:20:27: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
Jan  4 12:20:27: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
Jan  4 12:20:27: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Jan  4 12:20:29: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
Jan  4 12:20:29: %SYS-SP-5-RELOAD: Reload requested by Delayed Reload. Reload Reason: reload.
Jan  4 12:20:29: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
HERE I HAVE TO SEND A BREAK OTHERWISE IT WILL LOOP FOREVER WITH ERROR
And i dont know wht it uses bootvar string "boot bootflash:s72033-ipservicesk9-mz.122-33.SXI3.bin"
rommon 1 > boot
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, s72033_sp Software (s72033_sp-IPSERVICESK9-M), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 27-Oct-09 11:34 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x42252F40
*** System received an abort due to Break Key ***
signal= 0x3, code= 0x0, context= 0x50009798
PC = 0x4173ffbc, Cause = 0x2020, Status Reg = 0x34008002
rommon 2 > boot
Please reset before booting
rommon 3 > reset
rommon 1 > boot
           cisco Systems, Inc.
Image text-base: 0x40101328, data-base: 0x42249540
*Jan  4 12:28:41.247: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jan  4 12:28:41.247: %PFREDUN-6-STANDBY: Initializing as STANDBY processor for this switch
*Jan  4 12:28:42.755: %SYS-SPSTBY-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jan  4 12:28:41.447: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 08-Jun-09 11:01 by integ Build [100]
*Jan  4 12:28:42.755: %OIR-SPSTBY-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
Cat6k-Sup720/RP platform with 524288 Kbytes of main memory
Download Start
Download Completed! Booting the image.
Self decompressing the image : ########################################################################################################################################################################################################################################################################################################################### [OK]
           cisco Systems, Inc.
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
Compiled Tue 27-Oct-09 11:12 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x43A55C70
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509 (R7000) processor (revision 2.0) with 458720K/65536K bytes of memory.
Processor board ID SCA050306TD
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Virtual Ethernet interface
68 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Press RETURN to get started!
*Jan  4 12:30:15.235: RP: Currently running ROMMON from S (Gold) region
Jan  4 12:30:51: %SPANTREE-STBY-5-EXTENDED_SYSID: Extended SysId enabled for type vlan. The Bridge IDs of all active STP instances have been updated, which might change the spanning tree topology
Jan  4 12:31:06: %SYS-STBY-5-RESTART: System restarted --
Jan  4 12:31:06: %MFIB_CONST_RP-STBY-6-REPLICATION_MODE_CHANGE: Replication Mode Change Detected. Current system replication mode is Ingress
EUMAIXRM01_RM03-sp#exit
[Connection to Switch closed by foreign host]
BOOTLDR variable =
Standby is up
config registers looks fine.
Just want to ask is it your problem already solved?
if yes may i know how u solved it, because i happened the same problem as yours.urgent
thks
-gilbert
Pronoy Dasgupta
Hey,
Could you get the switch up by manual intervention, and give me the output of "show file system", and show boot.
For the supervisor 720 to boot off internal flash drives, the boot statement has to be boot system flash bootdisk:
For the network boot failure messages check the following out:
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K12495501
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K56745705
PD
This is the message i face :
rommon 15 > set
PS1=rommon ! >
SLOTCACHE=cards;
LOG_PREFIX_VERSION=1
BSI=0
ACL_DENY=0
RANDOM_NUM=1411880410
TYFIB_BLOCK_ALLOC=
PF_REDUN_CRASH_COUNT=1
CRASHINFO=crashinfo_FAILED
RET_2_RTS=01:27:57 UTC Fri Apr 30 2010
RET_2_RCALTS=1272590878
BOOT=bootdisk:s72033-ipservices_wan-mz.122-18.SXF11.bin
?=1
rommon 16 > reset
System Bootstrap, Version 8.5(2)
Copyright (c) 1994-2007 by cisco Systems, Inc.
Autoboot executing command: "boot bootdisk:s72033-ipservices_wan-mz.122-18.SXF11.bin"
Self decompressing the image : #################################################################################################### [OK]
           cisco Systems, Inc.
IOS (tm) s72033_sp Software (s72033_sp-IPSERVICES_WAN-M), Version 12.2(18)SXF11, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Fri 14-Sep-07 21:46 by kellythw
Image text-base: 0x40101040, data-base: 0x4146A1B0
00:00:04: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
Buffered messages:
Queued messages:
00:00:05: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 23-Aug-07 21:35 by integ Build [100]
00:00:05: %C6K_PLATFORM-0-UNKNOWN_CHASSIS: The chassis type is not known.(0xFFFF)
%Software-forced reload
Breakpoint exception, CPU signal 23, PC = 0x402DF044
-Traceback= 402DF044 402DCF90 40DA6E04 405B8A28 405BA104 40AB3ED0 40AC0E90 40AB5244 40AB3A64 4029C7C8 4029C7B4
$0 : 00000000, AT : 415E0000, v0 : 42330000, v1 : 41CC0000
a0 : 5002FDEC, a1 : 0000FF00, a2 : 00000000, a3 : 41490000
t0 : 402D1B68, t1 : 3400FF01, t2 : 402D1B68, t3 : FFFF00FF
t4 : 402D1B68, t5 : 6F6E736F, t6 : 65627567, t7 : 206F7574
s0 : 00000000, s1 : 414A0000, s2 : 00000003, s3 : 00000000
s4 : 00000000, s5 : 50C1DA68, s6 : 00000000, s7 : 41330000
t8 : 00000000, t9 : 00000000, k0 : 82EBCE10, k1 : 04372600
gp : 415E40F0, sp : 50C1D7B8, s8 : 41330000, ra : 402DCF90
EPC  : 402DF044, ErrorEPC : BFC1A4D0, SREG     : 3400FF03
MDLO : 00000000, MDHI     : 00000000, BadVaddr : 00000000
DATA_START : 0x4146A1B0
Cause 00000024 (Code 0x9): Breakpoint exception
File bootflash:crashinfo_20100430-014023 Device Error :No such device
=== Flushing messages (01:40:23 UTC Fri Apr 30 2010) ===
Buffered messages:
Queued messages:
00:00:05: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:00:05: %OIR-6-CONSOLE: Changing console ownership to switch processor
*** System recei?
rommon 1 >
Thks
-gilbert
It points toward a bad chassis.
Do u have any spare chassis to test this out.
HTH,
Rajeev.
Its not a bad chassis.  I just had the same issue today with a sup720-3b.  I have tried multiple chassis/codes/flash cards.  All my spare sup720's boot just fine in all the chassis I have tried and flash cards.  When I tried to load 12.2.18SFX code it came up with memory errors.  Bad sup module not chassis.  Any one know how to wipe the startup-config from ROMMON on a non-bootable sup?  Will be calling TAC to replace.
You can boot to ignore the startup configuration using 0x2142.
Type confreg 0x2142 at the rommon 1> prompt.
Once loaded you can write erase or edit the configuration the way you need.
The Sup won't boot any code.  So changing the confreg doesn't do anything for me.  Just wondering if there is a way from ROMMON (not booting up) to delete the startup config.
cristian.veres
I had the exact same problem. What I did is I broked it and at the rommon prompt I simply put boot with nothing else. That made the SUP boot up and I changed the boot string to boot from disk0: and I put the IOS on the compact flash in put it in slot 0. I didn't try to fix it from sup-boot-flash: to sup-bootdisk:, I just had a comact flash that I could spare and used it. I suspect the sup-bootflash got corrupted somehow.... Hope that helps....
