Clientless SSL VPN broken after upgrade 8.0(4) -> 8.0(5) ASA 5510
Dec 29th, 2009
I've got 3 ASA 5510, upgraded them all from 8.0(4) to 8.0(5) and ASDM 6.2(3)
Then I found out none of the three device responded anymore to WebVPN,
like there is nothing listening to https on the outside interface
I downgraded one back to firmwate 8.0(4) and everything worked just fine again.
Any ideas?
RicheeJJJ_2 Wed, 12/30/2009 - 13:01
I'm experiencing this same problem today. Did you find a solution yet?
riccardo-patti Thu, 12/31/2009 - 05:33
Have you backed up the all the config files of the appliance through
the utility into the asdm and restored it after the upgrade was done?
bvdijk@peterson.nl Mon, 01/04/2010 - 00:38
I've done the upgrade via the tools menu in  the Cisco ASDM, one whould expect that this should be the right way, since it was specially designed for upgrading.
(Ofcourse I make backups of my routers/firewalls etc. this is done on a daily basis by Kiwi Cattools)
bvdijk@peterson.nl Mon, 01/04/2010 - 00:36
Unfortunatly not yet, but I'm about to create a TAC request. When I've got the answer I will post it here.
