Cisco Ethernet over Copper Solution
Does Cisco have or plan to have a product that can compete directly with the Ethernet over Copper solutions from Actelis and Hatteras networks?
I have a project that I am working on where we are trying to work up a solution with Cisco products. I think the GHSDL is the only option that will work here in a back to back solution with a CO and CPE router on each end respectively.
Has anyone run into this?
Giuseppe Larosa Tue, 12/29/2009 - 13:53
we have tried to use LRE with C2950 LRE on one side and associated CPE on the other side to connect a remote side to a main office.
But we had not good results probably because the copper wires were not good.
Also we discovered we could not build etherchannel bundles using LRE ports.
using back to back GSDSL can be a solution to connect two small and near sites
Hope to help
