Is the X2-10GB-LRM compatible with 10GBASE-SR
Answered Question
Dec 29th, 2009
Is the X2-10GB-LRM compatible with 10GBASE-SR?
I have a 6500 with X2-10GB-LRM and a server with this NIC: The 10 Gigabit Ethernet-SR PCI Express Adapter is a low-profile, high performance fiber network interface controller (NIC). The product conforms to the IEEE, 802.3ae 10GBASE-SR specification for Ethernet transmission.
Thanks for your answer
Correct Answer by habadr about 7 years 6 months ago
Hi Gerardo,
X2-10GB-LRM uses 1300 nm wavelength, while the SR usues 850 nm wavelength.
If the Sever GBIC using the 850 nm wavelenght then you have to get the X2-10GB-SR GBIC.
Hatim Badr
Overall Rating: 5 (1 ratings)
Reza Sharifi Tue, 12/29/2009 - 09:24
  • Cisco Designated VIP,
    2017 LAN
They should be compatible.  Take a look at this table.
Also, here is the link to the entire document:
Table B-15 X2 Transceiver Cabling Specifications
X2 Transceiver Product Number
Connector Type
Wavelength (nm)
Cable Type
Core Size (microns)
Modal Bandwidth (MHz/km
Maximum Cabling Distance1
X2-10GB-SR
SC duplex
850
MMF
62.5
62.5
50.0
50.0
50.0
160
200
400
500
2000
85.3 feet (26 m)
108.3 feet (33 m)
216.5 feet (66 m)
269 feet (82 m)
984.3 feet (300 m)
X2-10GB-LR
SC duplex
1310
SMF
G.652 fiber
6.21 miles (10 km)
X2-10GB-ER
SC duplex
1550
SMF
G.652 fiber
24.84 miles (40 km)
X2-10GB-LX4
SC duplex
1310
MMF
62.5
50.0
50.0
500
400
500
984.3 feet (300 m)
787.4 feet (240 m)
984.3 feet (300 m)
X2-10GB-CX4
InfiniBand 4X
InfiniBand (copper)
49.2 feet (15 m)2
X2-10GB-LRM
SC duplex
1310
MMF
62.5
50.0
50.0
500
400
500
721.8 feet (220 m)
328 feet (100 m)
721.8 feet (220 m)
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/0bcabcon.html
Reza
Correct Answer
habadr Tue, 12/29/2009 - 13:47
  • Cisco Employee,
Hi Gerardo,
Hatim Badr
