queue logs
Dec 29th, 2009
Is there a log file to show how the queue flow should work. It appears I have a few agents taking most of the calls and a few agents not getting calls unless everyone in the queue avoids the call and it finally gets to the agent that hasnt had a call in an hour.
Jonathan Schulenberg Tue, 12/29/2009 - 10:21
  • Cisco Designated VIP,
    2017 IP Telephony
Is this Express or Enterprise?
If express, this is defined on the CSQ configuration within /appadmin. It will contain one or more skills and a selection algorithm. If it is most skilled (likely) then those agents with higher competency ratings in the same skill will always be offered calls first. Agents at the same skill competency level will be offered the call in a longest available fashion.
david.macias Tue, 12/29/2009 - 18:58
  • Blue, 1500 points or more
If Enterprise, take a look at the webview reports for a certain team or group of agents.  Check their time in ready/not ready state, this should point you to the culprits.
david
