ipv6 pim RP
Dec 29th, 2009
How do i configure a router to act as IPV6 RP for a specific multicast group.
Registration shld not be allowwed if any device / host try sending registration request for any other group.
i have seen some examples where acl is applied with "ip pim rp-address acl name" on all the routers in that domain , can't i control it on single router which is acting as RP?
Overall Rating: 0 (1 ratings)
Peter Paluch Tue, 12/29/2009 - 11:41
Hello Lokesh,
The IPv6 RP configuration is similar to the IPv4 style of configuration. You will need to create a named IPv6 access list that contains the list of permitted IPv6 multicast groups for which this particular IPv6 address shall serve as the RP.
For example:
ipv6 unicast-routing
ipv6 multicast-routing
ipv6 access-list MGroups
permit ipv6 any FF04::/64
ipv6 pim rp-address 2001::10:10 MGroups
In this example, the IPv6 address 2001::10:10 is assigned as the RP address for all multicast groups within the address space FF04::/64. These commands must be present on the RP and on all other routers. Note that the static configuration is inconvenient if the network is large. In larger networks, using the BSR mechanism to advertise the RP address for selected groups may be more appropriate.
Best regards,
Peter
Lokesh.Khanna Wed, 12/30/2009 - 04:42
Thanks Peter
I am trying to control Multicast for a specific multicast group address - FF08::10/128
And i get following error
ipv6 pim rp-address AB01:AB8:74:E:CE05:DFF:FE50:1 TST
%Error: Group prefix must be less than 128, skipping FF08::10/128
Am i missing some thing here?
Lokesh
Marwan ALshawi Wed, 12/30/2009 - 06:01
you are usin host prefix use smaller prefix
make your ACL with prefix /64
in your example FF08::/64
good luck
if helpful Rate
Lokesh.Khanna Wed, 12/30/2009 - 06:16
Will i not have ::/128 in my host prefix list
i tried following list and it didn't work for me.
IPv6 access list TST
permit ipv6 any host FF08::10
Lokesh
Marwan ALshawi Wed, 12/30/2009 - 06:32
this is host /128
like with ipv4 when you put host in ACL it will be /32
change to
permit ipv6 any host FF08::/64
then try it
good luck
if helpful Rate
Lokesh.Khanna Wed, 12/30/2009 - 09:50
HI
Thanks again for your quick response.
I am trying to understand concept here -
Objective is that RP should only work for multicast group FF08::10.
If i change ACL to permit ipv6 any host FF08::/64, will it not accept registration for all the hosts under FF08::/64 subnet?
Marwan ALshawi Thu, 12/31/2009 - 17:57
see the ACLs
ipv6 access-list ACL
permit ipv6 any FF08::/64
ipv6 access-list ACL1
i noticed that when i have the ACL with /64 for a grou range then i apply acl /128 for a group with the other ACL range i got the same error you have but if you try to apply again take it normally  see bellow
Router(config)#ipv6 pim rp-address 2001::1 ACL
Router(config)#ipv6 pim rp-address 2001::1 ACL1
Router(config)#
good luck
if helpful Rate
Lokesh.Khanna Thu, 12/31/2009 - 20:06
I also noticed same but it actually doesn't block other hosts.
I applied this ACL on RP router, and on other router i issues ipv6 mld join-group FF08::25
And i was able to ping that grp from other router in network.
Lokesh
Giuseppe Larosa Sat, 01/02/2010 - 02:49
Hello Lokesh,
you can try to use an ACL as an MLD access-group and to apply it on interfaces of routers.
This should give you control on what multicast addresses the receivers can join.
see
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-multicast_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1054034
MLD Access Group
The MLD access group provides receiver access control in Cisco IOS IPv6 multicast routers. This feature limits the list of groups a receiver can join, and it allows or denies sources used to join SSM channels.
Hope to help
Giuseppe
Lokesh.Khanna Sat, 01/02/2010 - 23:43
I tried this also and didn't work.
I think this is supposed to put restriction at receiver level on Access port.
It will not limit RP to allow registration for a particullar group.
So MLD will work but then i will have to apply it on each access port which i think is not scalable, Control should be on the router which is acting as RP.
enoualh100 Fri, 02/05/2010 - 10:56
hello,
i am getting the same error.
i tried the "ipv6 multicast group-range" but it didn't work as well.
omarmontes Fri, 02/05/2010 - 14:09
Same thing here.. exactly the same problem, and documentation for Multicast using IPv6 is kind of rare to find. Anyone got lucky on this?
Khaled Abuelenain Sun, 10/03/2010 - 13:21
Two solutions - both theoritically correct, but I could get neither to work :-)
ip pim accept-register list
or
If anyone can actually get either commands to work as expected, please post your full configs.
moitani Thu, 10/14/2010 - 16:00
I'm getting furious trying to make it work!!
when I match a host multicast will not flow....when I match a group multicast will flow!! Why?
Is this a bug??
