How Do I Reformat an MCS-7825H?
Dec 29th, 2009
Hello All,
Pardon the redundancy if you have just seen this question elswhere...
Anyway, can anyone out there point me to documents which define how to format an MCS-7825H? Currently it has CUPC on it and the need is now to re-format the hard drive to accept CentOS.
Thanks for any pointers!
Kind Regards,
Jerry
Jonathan Schulenberg Tue, 12/29/2009 - 12:52
The Virtual OS (VOS) platform that Cisco uses is in reality a Redhat Enterprise Server image. You should be able to use the native CentOS partitioning utility to modify the drive as you wish during install.
