HWIC-1FE on C2821 Router
Answered Question
Dec 29th, 2009
I've intalled two HWIC-1FE on a C2821 router. All 3 LED lights are on each card. However, the IOS does not see them...
Could you please help?
Frank
Correct Answer by Jon Marshall about 7 years 3 months ago
Frank
As you sh version shows you need to upgrade your IOS to a minimum of 12.4(15)T.
Jon
Frank
Frank
Check the IOS version you are running with a "sh version". You need a minimum of 12.4(15)T - note it must be a T train release -
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6_ps5855_Products_Data_Sheet.html
Jon
Overall Rating: 5 (2 ratings)
EPHRAIM MANI Tue, 12/29/2009 - 12:33
  • Bronze, 100 points or more
Please post sh version and sh diag output of the router. Thanks
Correct Answer
Jon Marshall Tue, 12/29/2009 - 12:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Frank
Jon
fntowo2009 Tue, 12/29/2009 - 12:54
Hi Jon,
Thanks for your help.
Doesn't my current IOS image support vlan config for HWIC-4ESW? The only option I get when entering the vlan command is accounting...
Frank
Jon Marshall Tue, 12/29/2009 - 13:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Frank
Have you seen my response in the other post ?
Jon
Jon Marshall Tue, 12/29/2009 - 13:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
fntowo2009 wrote:
Hi Jon,
Frank
Frank
Quick follow up. In the other thread i said it was
router# vlan-database
it's actually
router# vlan database
told you my memory was a bit suspect
http://www.cisco.com/en/US/docs/ios/lanswitch/command/reference/lsw_u1.html#wp1012545
Jon
Correct Answer
Jon Marshall Tue, 12/29/2009 - 12:41
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Frank
Frank
Jon
