L2L VPN failed inside on ASA 5520 (8.02)
Answered Question
Dec 29th, 2009
L2L VPN is dropping packets at Phase 5 because of a Configured rule. I have an isakmp sa but the client cannot connect to the destination here in my network. I'll post my access list config at bottom of Packet-tracer output.
vpnASA01# packet-tracer input inside icmp [10.0.0.243] 0 8 10.97.29.73 det
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xc92087c8, priority=12, domain=capture, deny=false
        hits=85188209121, user_data=0xc916a478, cs_id=0x0, l3_type=0x0
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xc87f1f98, priority=1, domain=permit, deny=false
        hits=85193048387, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.0.0.0        255.0.0.0       inside
Phase: 5
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0xc87f3670, priority=111, domain=permit, deny=true
        hits=67416, user_data=0x0, cs_id=0x0, flags=0x4000, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
============ACCESS-LIST + Config============
object-group network L2LVPN-blah_local
network-object 10.97.29.73 255.255.255.255
object-group network L2LVPN-blah_remote
network-object [10.0.0.240]  255.255.255.240
access-list INBOUND_OUTSIDE extended permit ip object-group L2LVPN-blah_remote object-group L2LVPN-blah_local
access-list L2LVPN-blah_obj extended permit ip object-group L2LVPN-blah_local object-group L2LVPN-blah_remote
access-list NONAT extended permit ip any [10.0.0.243]  255.255.255.240
route outside[10.0.0.240]  255.255.255.240 [10.97.29.1]  1
crypto map outside-VPN 46 match address L2LVPN-blah_obj
crypto map outside-VPN 46 set peer [10.0.0.243]
crypto map outside-VPN 46 set transform-set esp-sha-aes-256
crypto map outside-VPN interface outside
tunnel-group [10.0.0.243]  type ipsec-l2l
tunnel-group [10.0.0.243]  ipsec-attributes
pre-shared-key *
[10.0.0.1] is to protect clients global addresses. Assume these are all the same being used in place of the actual IP range. 10.0.0.240/28
Thanks in advance.
Michael Garcia
Lucrative Systems, Inc.
Correct Answer by busterswt about 7 years 5 months ago
Hi Michael,
After looking at your packet-tracer syntax, I think you have the source and dest IP swapped:
Yours: packet-tracer input inside icmp [10.0.0.243] 0 8 10.97.29.73 det
Proper: packet-tracer input [src_int] protocol src_addr src_port dest_addr dest_port [detailed] [xml]
Try swapping your IPs and see if that makes a difference.
James
P.S. I would also look at excluding the peer IP from the encryption domain by adding a deny statement for that particular IP before the permit for the network.
IE.
access-list L2LVPN-blah_obj extended deny ip object-group L2LVPN-blah_local host [10.0.0.243]
Hi Michael,
- Is the peer IP really part of the network that makes up the encryption domain?
- Is the INBOUND_OUTSIDE ACL applied to the inside (inbound) or outside (inbound) interface? In it's current form it would need to be on the outside interface.
- You've specified the peer IP only in the NONAT ACL, so all other traffic is being NAT'd and possibly denied since it does not match the encryption domain
Someone else may have some ideas, but these are questions I have at the moment.
James
Overall Rating: 5 (2 ratings)
Correct Answer
busterswt Tue, 12/29/2009 - 14:15
  • Bronze, 100 points or more
Hi Michael,
James
Michael Garcia Tue, 12/29/2009 - 14:25
James,
Yes this Peer IP is part of the encryption domain.
access-group INBOUND_OUTSIDE in interface outside
This is an error on my part... The NONAT is for the range, not the single IP. Sorry
access-list NONAT extended permit ip any [10.0.0.240]  255.255.255.240
Great Questions, thank you for your help!
Michael
Correct Answer
busterswt Tue, 12/29/2009 - 15:21
Hi Michael,
James
IE.
Michael Garcia Wed, 12/30/2009 - 14:49
thanks James, I have done that and I'm still not able to ping the clients peer. I had him debug ipsec, here's the debug my client is reporting.
Dec 30 16:47:57 [IKEv1]: Group = 65.114.207.251, IP  = 65.114.207.251, construct_ipsec_delete(): No SPI to identify Phase 2  SA!
Dec 30 16:47:57 [IKEv1]: Group =  65.114.207.251, IP = 65.114.207.251, Removing peer from correlator table failed,  no match!
I looked that up on the forum and there are a couple of reasons for this... either PFS is mismatched or ACLs are.
1) PFS is disabled by Default and I confirmed that it's disabled on both of our policies.
2) Our ACLs do not match. He's using a private IP range but he's not NAT'ing them to the public range.
His ACL -
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
access-list Outside_cryptomap_18940 extended permit ip 63.175.126.240 255.255.255.240 host 10.97.29.73
crypto map Outside_map 18940 match address Outside_cryptomap_18940
crypto map Outside_map 18940 set peer [my peer IP]
crypto map Outside_map 18940 set transform-set ESP-AES-256-SHA
access-list AS248 extended permit ip host 10.160.91.225 host 10.97.29.73
access-list AS248 extended permit ip 10.160.91.32 255.255.255.224 host 10.97.29.73
access-list AS250 extended permit ip host Unicenter-NSM host 10.97.29.73
access-list AS251 extended permit ip host Unicenter-DSM1 host 10.97.29.73
access-list AS249 extended permit ip host Unicenter-SD host 10.97.29.73
The 10.160.91.0/24 will not be routed on my network. This is where I would modify his access-list.
object-group network L2LVPN-Olympus_local
object-group network L2LVPN-Olympus_remote
network-object 63.175.126.240 255.255.255.240
access-list INBOUND_OUTSIDE extended permit ip object-group L2LVPN-Olympus_remote object-group L2LVPN-Olympus_local
access-list L2LVPN-Olympus_obj extended deny ip object-group L2LVPN-Olympus_local host 63.175.126.243
access-list L2LVPN-Olympus_obj extended permit ip object-group L2LVPN-Olympus_local object-group L2LVPN-Olympus_remote
access-list NONAT extended permit ip any 63.175.126.240 255.255.255.240
this is still broken. We get Phase1 but no Phase2... I'm convinced that this is the problem.
any thoughts?
Michael
Michael Garcia Wed, 01/06/2010 - 10:55
James,
The final resolution was to change encryption domain from x.x.x.240/28 to x.x.x.248/29. This took the peer address of x.x.x.243 out of the Encryption domain and the tunnel came up immediately. I'm not sure why but using the access list to remove that peer from domain didn't work. I was able to convince the client to make the change and all is well in the world again. Thanks!
Michael
