VG 204 Config
Dec 29th, 2009
Can someone post a basic VG204 config file so I can compare it with one I have for our fax machines.  We are running CCM 6.1 with what I believe is a H323 Gateway... I think... How could I tell if I have H323 or MGCP?
TIA
steigja Sun, 01/03/2010 - 16:46
You can tell what type of gateway you have configured by going to devices --->gateway, then click find.  It will say what type of gateway you have configured in the icon to the left of the "device name".  You can add a VG204 as a gateway here and it will be configured using SCCP. You can then configure the 4 FXS ports of the VG204 as if they are SCCP devices.  This is the easiest way to configure the VG gateways.  there are commands needed on the VG side.  Check out this link, please rate if helpfull, thanks.
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsbasic.html
Here is a sample configuration for a vg224(same thing just 24 ports instead of 4) using SCCP.
Cisco IOS Gateway SCCP Analog Ports Configuration: Example
The following example shows a configuration for a Cisco VG224 Analog Phone Gateway in Cisco IOS Release 12.4(2)T.
Router# show running-config
Building configuration...
Current configuration : 3442 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource manager
ip subnet-zero
no ip dhcp use vrf connected
no ftp-server write-enable
stcapp ccm-group 1
stcapp
stcapp feature access-code
 prefix *#
 call forward all 2
 call forward cancel 9
stcapp feature speed-dial
 prefix ##
 redial 9
 voicemail 8
 speed dial from 3 to 7
template address
voice-card 0
interface FastEthernet0/0
 ip address 10.4.138.5 255.255.0.0
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip default-gateway 10.4.0.1
ip classless
ip route 223.255.254.0 255.255.255.0 10.4.0.1
ip http server
control-plane
voice-port 2/0
 caller-id enable
voice-port 2/1
 caller-id enable
voice-port 2/2
 caller-id enable
voice-port 2/3
 caller-id enable
voice-port 2/4
voice-port 2/23
sccp local FastEthernet0/0
sccp ccm 10.4.131.200 identifier 7815
sccp ccm 10.4.138.77 identifier 7825
sccp
sccp ccm group 1
 associate ccm 7815 priority 1
 associate ccm 7825 priority 2
dial-peer voice 500 pots
 service stcapp
 port 2/0
dial-peer voice 501 pots
 service stcapp
 port 2/1
dial-peer voice 502 pots
 service stcapp
 port 2/2
dial-peer voice 503 pots
 service stcapp
 port 2/3
dial-peer voice 504 pots
 service stcapp
 port 2/4
dial-peer voice 523 pots
 service stcapp
 port 2/23
line con 0
 exec-timeout 0 0
 transport preferred all
 transport output all
line aux 0
line vty 0 4
 login
 transport input all
end
http://www.cisco.com/en/US/docs/routers/access/vg202_vg204/software/vg2_vg4_voip_ps2250_TSD_Products_Configuration_Guide_Chapter.html
Hi there,
You also need these statements adding
The config server being your tftp server
The third option is your local gateway if you want your analogue devices to work in srst.
ccm-manager config server 10.8.33.19   (TFTP Server )
ccm-manager config
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
sccp ccm 10.8.33.11 identifier 10
sccp ccm 10.8.33.12 identifier 20
sccp ccm 10.9.24.8 identifier 30       ( Third Option Local Voice Gateway)
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 10 priority 1
associate ccm 20 priority 2
associate ccm 30 priority 3
Dave
Related Content
