Site2Site between ASA & Linux Racoon
Dec 29th, 2009
Hi All,
I need help in troubbleshooting this issue: Site2Site vpn between an Asa 5520 and a Linux Box is up as shown
ciscoasa# sh crypto isa sa
   Active SA: 1
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1   IKE Peer: 82.112.199.148
    Type    : L2L             Role    : initiator
    Rekey   : no              State   : MM_ACTIVE
ciscoasa# sh crypto ipsec sa
interface: outside
    Crypto map tag: outside_map, seq num: 1, local addr: 82.88.171.211
      access-list outside_1_cryptomap permit ip 10.15.0.0 255.255.0.0 10.57.6.0 255.255.254.0
      local ident (addr/mask/prot/port): (10.15.0.0/255.255.0.0/0/0)
      remote ident (addr/mask/prot/port): (10.57.6.0/255.255.254.0/0/0)
      current_peer: 82.112.199.148
      #pkts encaps: 1181, #pkts encrypt: 1181, #pkts digest: 1181
      #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 1181, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 82.88.171.211, remote crypto endpt.: 82.112.199.148
      path mtu 1500, ipsec overhead 58, media mtu 1500
      current outbound spi: 08F0DA33
    inbound esp sas:
      spi: 0x775D8D2C (2002619692)
         transform: esp-3des esp-md5-hmac no compression
         in use settings ={L2L, Tunnel, PFS Group 2, }
         slot: 0, conn_id: 12288, crypto-map: outside_map
         sa timing: remaining key lifetime (kB/sec): (3915000/746)
         IV size: 8 bytes
         replay detection support: Y
Anti replay bitmap:
        0x00000000 0x00000001
    outbound esp sas:
      spi: 0x08F0DA33 (150002227)
         sa timing: remaining key lifetime (kB/sec): (3914966/746)
         IV size: 8 bytes
Anti replay bitmap:
but i get the following error:
ciscoasa# debug crypto isakmp
ciscoasa# Dec 29 22:10:11 [IKEv1]: Group = 82.112.199.148, IP = 82.112.199.148,                                               QM FSM error (P2 struct &0xc86c5b30, mess id 0xdec7ea9b)!
Dec 29 22:10:11 [IKEv1]: Group = 82.112.199.148, IP = 82.112.199.148, Removing p                                              eer from correlator table failed, no match!
Dec 29 22:10:21 [IKEv1]: Group = 82.112.199.148, IP = 82.112.199.148, QM FSM error (P2 struct &0xc8def038, mess id 0xdec7ea9b)!
Dec 29 22:10:21 [IKEv1]: Group = 82.112.199.148, IP = 82.112.199.148, Removing peer from correlator table failed, no match!
Dec 29 22:10:33 [IKEv1]: Group = 82.112.199.148, IP = 82.112.199.148, QM FSM error (P2 struct &0xc8def038, mess id 0x86e6402c)!
Dec 29 22:10:33 [IKEv1]: Group = 82.112.199.148, IP = 82.112.199.148, Removing peer from correlator table failed, no match!
Dec 29 22:10:43 [IKEv1]: Group = 82.112.199.148, IP = 82.112.199.148, QM FSM error (P2 struct &0xc8def038, mess id 0x86e6402c)!
Dec 29 22:10:43 [IKEv1]: Group = 82.112.199.148, IP = 82.112.199.148, Removing peer from correlator table failed, no match!
riccardo-patti Thu, 12/31/2009 - 05:22
The problem was regarding the policy applied by the linux Kernel.
Riccardo
