WCS 4.1 - How to delete events?
Answered Question
Dec 30th, 2009
I was wondering if it's possible to delete all the events that get logged on WCS? There is no check box or select a command drop down list.
I have 10K+ events which I presume are being backed up every time.
I can delete alarms but not events.
Any clues?
Correct Answer by Nael Mohammad about 7 years 2 months ago
Alerts are kept until they are cleared and by default remain for 7 days before being purged from the database. WCS keeps the last 40,000 events in the system and clears them after 7 days. Events lead to alerts and events get cleared up after 7 days automaticly.
Let me know if this is what you are looking for.
-nael
Overall Rating: 5 (1 ratings)
Correct Answer
Nael Mohammad Wed, 12/30/2009 - 14:43
-nael
mbhnt Thu, 12/31/2009 - 03:12
ah ok, yeah that's fine - i did'nt actually check the dates on them, so I probably could have worked out that they are purged automatically.
thanks
Trending Topics - Security & Network
