RPS 2300 & amount of switch backup
Dec 30th, 2009
Cisco states in FAQ that RPS 2300 can only actively backup 1 Switch with 1 PowerSupply.
Can somebody answer, why is that ?
Is there a limitation in switching the power to more than one outside connectors ?
otherwise this would be a fine backup solution for some more Switches w/o PoE.
regards,
Stefan
ansalaza Wed, 12/30/2009 - 06:25
  • Cisco Employee,
RPS2300 can backup 2 Switches if RPS2300 has two power supplies:
Table 1. Number of Switches Actively Backed Up by the Cisco RPS 2300
Cisco RPS 2300 Power Supply Configuration
1 x 750W
2 x 750W
1 x 1150W
2 x 1150W
Cisco Catalyst 3750-E or 3560-E switches with 1150W PS
Not supported
All other supported network devices
https://www.cisco.com/en/US/prod/collateral/switches/ps5718/
ps7148/ps7130/prod_qas0900aecd805bbf21.html
STEFAN KLUEPPEL Wed, 12/30/2009 - 10:00
sorry,
perhaps I did not define the question clear enough
How is the power switching done internally ?
From logical point of view there is plenty of power available from 1 power supply
for several non-PoE-Switches. Why is that, that only 1 switch can be powered ?
glen.grant Wed, 12/30/2009 - 11:05
  • Purple, 4500 points or more
  In real world scenarios you wouldn't need to power more than 1 or 2 .  These are remote power supplies to power a switch if the internal switch power supply craps out . It is not a UPS (battery backup)  if you lose power to a site .  They are used so that the switch will continue to run while you get a replacement switch power supply . A good FAQ.
https://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7148/ps7130/prod_qas0900aecd805bbf21.html
STEFAN KLUEPPEL Tue, 01/05/2010 - 02:37
Hi Glen,
well my questions source from real-world scenario and points to the lack of
uninterruptable switchover of c2960 Series switches which our customers want
to avoid.
Thanks for the FAQ. I already mentioned that I read them in my first posting.
Seems to be no standard solution.
regards,
Stefan
Related Content
