CIscoworks and ACS integration issue.
Dec 30th, 2009
I found this issue in ACS. When clicking the shared profile components in ACS. the following errors occur.
"XML schema for this service type is not installed. Please reinstall the service type which should properly install the XML schema as well."
Rajiv.
Joe Clarke Wed, 12/30/2009 - 09:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Try going to Common Services > Server > Security > AAA Mode Setup.  Check the box, "Register all installed applications with ACS", then re-apply your ACS settings.  This should reinstall the necessary XML files for LMS role setup.
