how to set antenna in 4.2.207.0
Dec 30th, 2009
I have just installed some Cisco 1252's using 4402 wlc on 4.2.207.0.
But in this release it is'nt possible to set the used antenna ports. Recently updated to 6.0.188.0 just to check, and in this version you have the possiblity to choose antenna ports.
Is'nt 4.2.207.0 supposed to support the 1252 AP's and it's settings?
George Stefanick Wed, 12/30/2009 - 14:30
Yes, you are correct 4.2 does support the 1252 access points. But like anything else, as newer releases come out more functions are added.
