Kureli Sankar Wed, 12/30/2009 - 05:31
1)what is the function of this module:CSC-SSM? and how it connect physicaly  to network?is it on the inside or outside or DMZ?
The CSC can be plugged in anythere.  All it needs is access to the internet. Just think of it as a PC in your network. You can connect is just like anyother pc or server in your network or completely on the outside as well.
2)if i have 2 asa for hight availability ,do i need to have 2?
Absolutely ! Otherwise the hardware will not match and failover will not work.
