Netflow configuration on a 7603. Please assist. Thanks
Dec 30th, 2009
I am attempting to configure my 7603 running (cat 6000 sup 2 blade) to send netflow information to Netflow server but un-succesfull.  Below is the config that I did.
interface port-channel 1
ip route-cache flow
ip flow-export source port-channel 1
ip flow-export version 5
ip flow-export destination (server IP) 2055
The only option I have after configuring "ip route-cach flow" is "ip flow ingress"
Please assist in providing the correct configuration to send all netflow traffic to server.
CSCO11167812 Wed, 12/30/2009 - 07:27
Can you ping the destination address from the 7603.
And did you apply the ip flow ingress or ip flow egress command to the interface you want to capture
Michel
