Configuring Dual SUP on 6509
pipsadmin
Hi all,
I have a 6509 with dual SUP2-MSFC2
Which slot should they be in and how to configure them as redundant?
10 Replies 10
mikegrous
Level 3
Level 3
https://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper09186a0080088874.html
The Cisco Catalyst 6500 Series can support up to two supervisor engines (slots 1 and 2 for the Supervisor Engine 1A and Supervisor Engine 2; and slots 1 and 2 in the Cisco Catalyst 6503 and 6504 chassis, slots 5 and 6 in the Cisco Catalyst 6506 and 6509 chassis, and slot 7 and 8 in the Cisco Catalyst 6513 chassis for the Supervisor Engine 32 and Supervisor Engine 720) with one being the running, or active, supervisor engine and the other being the standby supervisor engine.
OK, so my 2 sup's are in slot 1 and 2
Now how do I configur redundance?
redundancy is configured, yet my 2 sup's, 1 is active and 1 is standby COLD. How do I m
ake it standby HOT ? so not to cause network outage when it switches?
Also, is there a command to force the switchover?
On a 6509, your Sups must go into slot 5 and 6
Slot 1 and 2 will not work
Reza
I beg to differ... I have the 2 sups in mod 1 and 2 :
Router#sh mod
Mod Ports Card Type                              Model              Serial No.
  1    2  Catalyst 6000 supervisor 2 (Hot)       WS-X6K-S2U-MSFC2   SAD054907B8
  2    2  Catalyst 6000 supervisor 2 (Active)    WS-X6K-S2-MSFC2    SAD05030E85
  3   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-TX     SAD073702F7
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0001.c9da.d09c to 0001.c9da.d09d   3.2   7.1(1)       12.2(18)SXF1 Ok
  2  0013.c40a.f0f8 to 0013.c40a.f0f9   2.19  7.1(1)       12.2(18)SXF1 Ok
  3  000d.bd0c.a6d0 to 000d.bd0c.a6ff   3.0   7.2(1)       8.5(0.46)RFW Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Policy Feature Card 2       WS-F6K-PFC2        SAD054907W2  3.0    Ok
  1  Cat6k MSFC 2 daughterboard  WS-F6K-MSFC2       SAD0549061D  1.3    Ok
  2  Policy Feature Card 2       WS-F6K-PFC2        SAD050300X3  1.6    Ok
  2  Cat6k MSFC 2 daughterboard  WS-F6K-MSFC2       SAD05030Z8X  1.15   Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
Router#
Router#sh redundancy
Redundant System Information :
       Available system uptime = 1 hour, 1 minute
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Duplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 2
        Current Software state = ACTIVE
       Uptime in current state = 1 hour, 0 minutes
                 Image Version = Cisco Internetwork Operating System Software
IOS (tm) s222_rp Software (s222_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 25-Sep-09 01:53 by ccai
                          BOOT = disk0:s222-ipservicesk9_wan-mz.122-18.SXF17.bin,1;
                       BOOTLDR = bootflash:c6msfc2-boot-mz.121-20.E6
        Configuration register = 0x2102
Peer Processor Information :
              Standby Location = slot 1
        Current Software state = STANDBY HOT
Router#
The following line indicates it is standby HOT.
jerry
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c0eb0.shtml#backinfo
The above link nets you this:
Supervisor Engine 2
WS-X6K-S2-PFC2
WS-X6K-S2-MSFC2
WS-X6K-S2U-MSFC2
My mistake before:
SUPERVISOR ENGINE 2-MSFC2
Suited for deployment in the distribution/core with Classic interface modules, CEF256 interface modules and dCEF256 interface modules, Supervisor 1A-2GE provides Layer 2/3/4 forwarding with the following operational advantages:
• Layer 2-4 forwarding-Performs Layer 2-4 forwarding with Layer 2, 3, 4 features; supports dCEF256 interface modules
• Media Access Control (MAC) addresses-128K
• Forwarding rate-Up to 30 Mpps per system
• Bandwidth-32 Gbps per system; 256 Gbps with SFM in chassis
• Layer 2, 3 traffic classification and marking-Layer 2 and Layer 3 (See Table 3-QoS Features Comparison for details)
• Multilayer (Layer 3) switching-IPv4 supported (See Table 6 for details)
• Distributed forwarding-Requires Switch Fabric Module and interface modules with Distributed Forwarding Cards (DFCs); for details, see section titled How Distributed Cisco Express Forwarding (dCEF) Works
• Operating system-Cisco Catalyst OS with Cisco IOS on the MSFC and Cisco IOS Software
• Management tools-SPAN, RSPAN, VACL capture
• DRAM-128, 256, 512 MB
• Onboard flash (BootFlash)-32 MB
• Chassis supported-Cisco Catalyst 6006, 6009, 6503, 6506, 6509, 6509-NEB, 6509-NEB-A, and 6513; 7603, 7606, 7609, OSR-7609, and 7613
• Slot requirements-Slots 1 or 2 of any chassis
• Upgrade support-None required
This link should help with your redundancy Question. Basically SSO is good.
https://supportforums.cisco.com/docs/DOC-4028;jsessionid=FA757931D85D904CAB941734E1052C72.node0
Thanks for the correction
I was thinking about Sup-720 when I responded
Reza
