Cisco 7609-S:%C7600_MEM_ECC-3-SYNDROME_MBE:
Dec 30th, 2009
Hello :
    I have 7609-S rebooted on its own and left one crashinfo file.
CMD: 'show diag' 03:12:31 WET Wed Dec 30 2009
CMD: 'show module' 03:12:31 WET Wed Dec 30 2009
CMD: 'show inventory raw' 03:12:31 WET Wed Dec 30 2009
CMD: 'show diag' 04:12:36 WET Wed Dec 30 2009
CMD: 'show module' 04:12:36 WET Wed Dec 30 2009
CMD: 'show inventory raw' 04:12:36 WET Wed Dec 30 2009
CMD: 'show diag' 05:12:52 WET Wed Dec 30 2009
CMD: 'show module' 05:12:52 WET Wed Dec 30 2009
CMD: 'show inventory raw' 05:12:52 WET Wed Dec 30 2009
000933: Dec 30 05:34:55.356 WET: %C7600_MEM_ECC-2-MBE: Multiple bit error detected at 0x0A69A820
000934: Dec 30 05:34:55.356 WET: %C7600_MEM_ECC-3-SYNDROME_MBE: 8-bit Syndrome for the detected Multi-bit error: 0xCC
=== Start of Crashinfo Collection (05:34:55 WET Wed Dec 30 2009) ===
For image:
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRC2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 18-Sep-08 03:16 by prod_rel_tea
------------------ show version ------------------
Compiled Thu 18-Sep-08 03:16 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRB4, RELEASE SOFTWARE (fc1)
LouresMSC-r6510 uptime is 4 hours, 2 minutes
Uptime for this control processor is 4 hours, 2 minutes
System returned to ROM by s/w reset (SP by bus error at PC 0x82AC27C, address 0x0)
System restarted at 05:36:40 WET Wed Dec 30 2009
System image file is "bootdisk:/c7600rsp72043-advipservicesk9-mz.122-33.SRC2.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco CISCO7609-S (M8500) processor (revision 1.0) with 1835008K/131072K bytes of memory.
Processor board ID FOX1205GPGM
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
5 Virtual Ethernet interfaces
98 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
I have found one bug (CSCta53511) but the IOS is not affected by this behaviour. Can anyone know is there any known sw defect?
Arjun
Reza Sharifi Wed, 12/30/2009 - 08:05
Hello Arjun,
The crash is caused by software bug not switch defect.  Open a TAC case and send them the crash file to be analyzed.  Most likely you have to upgrade to a different ver of IOS.
Good Luck
Reza
