cant manage asa from remote location
gmtimmons
have l2l vpn connection with remote location.  They have asa 5505 we have asa 5520 as firewall/vpn devices.  I can communicate with EVERYTHING at the remote location except the 10.244.12.1 (asa inside interface) from headquarters.  I can remote to a pc at that location and manage it fine, but need to be able to do it from HQ.    config is attached.  thanks for any advice.
Kureli Sankar
Could you remove this line
management-access mgmt
and add this one?
management-access inside
Also, you are only allowing ssh to the mgmt interface. Make sure to allow that to the inside interface as well.
-KS
Kureli Sankar
and add this one?
-KS
gmtimmons
Thank you,   The management-access mgmt line wasnt in there to remove,  so I simply added the management-access inside.....that did the trick... I have been banging my head against the wall.....I knew it would be something simple.  thanks again
Glad to hear.  Thanks for rating.
I thought I saw the line in the config. May be I looked at some other config.
If it is not there then yes, you just simply add that line.
-KS
